Results 1 to 3 of 3
Thread: Auto trans
    Aug 2011
    15
    Default Auto trans
    Has anyone tried running an automatic behind the ford 2.3 in a mini stock?
    Just curious since there used in street stocks and modifieds quite a bit.....
    A few have tried them around here. Lack of durability has been the biggest problem.Also loss of HP is a big negative.I havent looked up the numbers but I would expect to loose 20% engine power through the automatic.V8 engines can afford to loose some power 4cyl's. can't.
    340
    Default Fun to try a C3
    I wish I had more time to experiment.
    A C3 has REALLY light internal parts but probably is strong enough as it came behind some V6s.
    It would be fun to set one up with a direct drive hub(no torque converter)behind one of our 2.5's.
    I think any serious racing automatic behind a 4 cyl would need to be direct drive due to rotating weight and inefficiency of a converter.
Copyright © 2021 vBulletin Solutions, Inc. All rights reserved.
