3 link springs
running a 3,000 lb car. currently running 16" on the rear 225 on lr and a 175 on the rr, 900 rf, 800 lf. was thinking of moving the 225 to the rr and putting a 250 or 275 on the lr, have only ran the car once as a 3 link and it seems to be a tad tight getting in, and then will snap loose exciting the corners.
How much le is in the car, I would leave those springs in the car and work on it with scale numbers
I think all of your springs may be too light for a 3000# car...
sorry it took so long to get back to you guys, im not sure what you mean by "le"... right now the car is 3,000 lbs, 52.6 rear, 120 lbs bite, 51.5 cross, 20" panhard, 3" rake.
Sorry put more lr in the car will loosen it up on entry and tighten up on exit. Your at 120 lr maybe try 160 lr see if that helps
The change you describe sounds good! It will be more consistant with heaver springs in the back also.
