Body weight
Results 1 to 7 of 7
Thread: Body weight
    Default Body weight
    I have the following springs on my 4 bar rayburn:
    Lf 600 rf 400
    lr 200 rr 225
    i weigh 260 lbs. Should my rear spring weights be a little heavier?
    I know they dont plan them with someone weighing that much.
    Reason i ask lr sets down pretty hard off gas going in.
    I have a 8-2 gas shock on lrb back only.
    I know i need to trail brake better also.
    Thanks
    Jun 2009
    Central IL
    580
    The car doesn't car where the weight comes from. It only cares about how where your weight is located and what your scale numbers are. Doesn't matter if the weight comes from you or from lead. As long as you scale the car with you in it (or weights in your place), and you have good shocks, you shouldn't need to change spring, unless you're unhappy with the handling. That's just my view on it though. 200 LR isn't out of the ballpark.
    Port St. Lucie, FL/Sardinia, OH
    4,773
    You would probably benefit from more compression damping on the lr wheel.
    2013 Race Night Count - 25
    East Bay - 4............................North Florida -1
    Waycross, GA - 1.....................I77 -1
    Bubba Raceway - 1..................Eldora -2
    Jackson Co. (OH) - 6
    Moler Raceway - 5
    Lawrenceburg -1
    Brushcreek - 1
    Twin Cities -1
    Portsmouth -1
    in a van down by the river
    728
    Default mod
    what about a brake floater on the LR. that would help wiht trail braking, and keeping car on the bars. Would also lessen the need for more compression on the LR.
    4,773
    Quote Originally Posted by JustAddDirt View Post
    That can work too. Plenty of ways to skin a cat.
    Moler Raceway - 5
    Lawrenceburg -1
    Brushcreek - 1
    Twin Cities -1
    Portsmouth -1
    Mastersbilt racer
    how much more compression dampening would or should you go?
    4,773
    Quote Originally Posted by money17 View Post
    Mastersbilt racer
    I can't really answer that because one person's 8-2 shock may not be the same as someone else's.
    Moler Raceway - 5
    Lawrenceburg -1
    Brushcreek - 1
    Twin Cities -1
    Portsmouth -1
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
