Racer garage sale
for pics text me or go to the ncraceparts website 704 658 7313
krc power steering tank $20
ovalcraft power steering tank with #6 and #10 return lines $25
ovalcraft tank with breather for rear end or tranny. $20
winters 007 wide 5 oil bath hub with 2 new in box angular contact bearings, gun drilled studs. front hub, very lite. $85
(2) wilwood wide 5 starlite 55 hubsfront or rears. $45 ea or $75 for pair
wilwood starlite 55 drive flange $25
wilwood wide 5, 8 bolt hub $40
csr white window net $10
blue window net $10
red window net $10
fender fill with gas cap and clear hose $10
quick car ign control panel $25
quick car oil pressure gauge $20
afco rear motor mounts $15 pair
wilwood 7/8" and 1 " master cylinders $40 pair
howe g3 remote mount master cylinders 7/8" and 1" $40 pair
(new) afco 7/8" master cylinder $35
tilton kit for remote mounting master cylinders $15
wilwood cast 4 piston caliper LF. 1.88/1.75 pistons $45
billet fuel log for 4 brl carb. $45
shifter boot by performance analysis, sfi 2/10 $15
(2) howe m/ss style adjustable upper control arms complete with hiems $35 pair
(2new) lefthander 10 1/2" upper a-arms $35 ea $60 pair
(new) lefthander 9" upper a-arm $35
(new) lefthander 11 1/2" upper a-arm $35
(new)lefthander spindles, ball joints, and lowers. 1 complete left side and 1 complete right side. $125 side or $200 for whole deal
2 used 9 1/2" upper a-arms $25 pair
1 piece howe style bent sway bars. 1.5" $65, 1.25" $60, 1.125 $45, 1" $40. $150 for set
(new) 1 7/8" spline sway bar 1.5" ends $125
right and left sway bar ends for 1.5" bar $75 pair
five star cold air box. $75
3 custom built cold air boxes with bases/bells, $60 for all
k&n 2 brl flow control air cleaner assembly $45
bump steer gauge wth dual 1" dials. similar to irvan smith. $50
lajoie full containment seat $750. go to ncraceparts for more details
buttler ex dave blaney sprint cup seat. $650 go to ncraceparts for more details
franklin qc rear end with alum spool, w5 snouts. 3" offset tubes. set up for 65" tread width with 5" and 4" offset wheels $375
penske rebuild shim and seal kit with 1qt penske oil and joes shock wrench. $100 for all
(2) 7" steel body penske 7100 series. $100 ea
(2) 7" steel body penske 700 series with coleman heat shrink coil over threads $120 ea
(2) 9" steel body penske 7100 series $100 ea
(2) 8" alum body penske 7300 series (nationwide/ sprint cup style) with rebound adj. shafts. can do coil over kits with these. $595 pair, retail $800 a piece new
can build to suit
i have springs. probably 150-200. 2.5" coil over. many 5" and 5.5 stuff.
gm 602 crate engine with front pullys, water pump, power steer pump, and hei distributor. $1800
5.5 quarter master 3disk v-drive clutch, have 10 or 26spline disks to go with. have flywheel for gm crate engine or standard sbc style $350
5.5 quarter master 3 disk pro series clutch, have 10 or 26 spline disks to go with. flywheel is sbc type "built motor" $350
(2)new set of 3, 5.5 quarter master clutch disks. 10 spline disks $70, 26 spline disks $80
have alot more stuff just ask. dont be afraid to make offers, more than willing to work on package deals if you buy a couple things.
I am looking for a 650# or 700# 5" x 9.5" spring. Got one?
