Results 1 to 8 of 8
    Default gear identification help!!
    friend has a 3rd member laying around and were trying to figure out the gear ratio on it and here is the numbers on the ring gear C or g 2aw 4210e
    dillonsolumracing.weebly.com
    Glasgow, Kentucky
    4,823
    Count the number of teeth on each gear.
    Mar 2012
    Victoria il
    114
    count teeth on ring and pinon then divide the ring by the pinon = ratio
    Dec 2008
    1,098
    rotate the axles 10 revolutions an count how many times the yoke turns,..can figure it real close,..a 6:50 gear would be 6 an half revolutions of yoke,..6:33 would be 6 an a third turns....good luck...
    thanks for the tips, it wasnt what we were looking for,
    how big of a rpm difference will there be if switching from a 5.87 to a 6.33?
    car was only turning 5500 before and just curious if anyone know how many rpms more to expect. thanks
  6. #6
    Mar 2012
    Victoria il
    114
    At leAst 600
  7. #7
    Mar 2012
    Victoria il
    114
    200 to300 per ratio
  8. #8
    Glasgow, Kentucky
    4,823
    Rough idea, (RPM / old gear) X new gear = rpm
    5500 / 5.87= 936.967632..... SO 936.97 X 6.33 = 5931.02 rpm.
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
