Results 1 to 2 of 2
    Feb 2012
    19
    Default Alky plugs for double humps
    What is a good alky plug for double hump heads?
    Motor is a 360 with cast pistons
    PA
    844
    Autolite Racing in 32 or 33 heat range, not sure on the actual number. Or you could use NGK v power that crosses from the AR number.
    Josh K.
