04 Berheisel Setup help needed
Ive got a 2004 Bernheisel overslung how do i want to go about judging how long the chain should be for the right rear tie down , is there a proces for the overslung cars ? thanks for any help RSW
I don't think you need a chain on the RR. The RR won't drop like the LR under acceleration. Th only time it should drop is when you jack it up. The shock will keep it from dropping at that point. If you want to put a chain there, I would say just before it reaches full shock extension.
