Results 1 to 13 of 13
Thread: oil tank
    Feb 2009
    139
    Default oil tank
    Which oil tank is better round or square or is there a difference
    3,436
    Its all about air/oil seperation.Round or square doesnt matter.
    738
    Quote Originally Posted by perfconn View Post
    With that said which brand do you recommend? MCT? Butlerbilt? Peterson? PRC?
    3,436
    MCT.Mike does good work.
    Feb 2009
    139
    The reason i ask we have a clements engines and they want us to throe our square tank away and get round tanks not sure the reason we have a mct tank in our car and itt is not baffled properly and spit oil from the breather all over so we cant fill the tank to the window
    3,436
    Do you have the engine sealed and have the Peterson popoff valve on the valve cover or do you run it with breathers on the valve cover?
    Feb 2009
    139
    Pop off valve in the cover was told that some of the tanks had the baffles made wrong or something like that same motor our other car no problem
    3,436
    Suggest you call Mike.If there is a problem with the tank I'm sure he will take care of it.
    Dec 2007
    Midwest America
    191
    When they start making square toilets I might consider a square tank. Until then, I will stick with round.
  10. #10
    3,436
    What does a toilet have to do with a drysump tank.
  11. #11
    Glasgow, Kentucky
    4,852
    If you watch a toilet flush, it actually aerates the water, not what you want in an oil tank.
    AND they do make square toilets.
    http://images.search.yahoo.com/image...&fr=chrf-yff13
  12. #12
    Jul 2007
    538
    Round tanks help de-aerate the oil better than square tanks. If you have a square tank it needs to at least have some curved section in it.
    Basically the most ideal tank is round, skinny, with conical plates inside.
  13. #13
    Glasgow, Kentucky
    4,852
    Quote Originally Posted by FlatTire View Post
    I do not agree on the skinny part as you would want the most surface area available to allow trapped air out. A skinny tank would allow air to be pushed down as more oil comes into the tank. This is why Nascar uses tanks that are about 18 inches in diameter.
