Results 1 to 7 of 7
    Nov 2010
    Lock Haven, Pa
    664
    Default Rebuilding/servicing a Brinn
    Trying to save a little money and do some of my own maintenance this year. I see Brinn has rebuild instructions on their website. Any problems I should be aware of?
    Also my Brinn doesn't have the output shaft turned down ahead of the splines to accept an 8" yoke. Can this be turned down at a machine shop, or is it too hard?
    DeWitt IA
    414
    the best way to turn down the output shaft is to have it turn on a crank grinder .
    May 2010
    632
    I know it's not the correct way but on my saginaw we used a grinder, used it for a year with no problems
    Mar 2011
    197
    Quote Originally Posted by dirttrackrocker View Post
    As far as doing it yourself.... We have a transmission Guy that Races around here and he says anyone can work on a Brinn, but if you got a bert.... you gotta have special tools and about 4 hands....
    Nov 2010
    Lock Haven, Pa
    664
    Quote Originally Posted by johnny v View Post
    I have heard the same about Berts, the instructions on the Brinn site don't sound too complicated.
    Thanks for the replies.
    tulsa america
    2,687
    You need an extremely good pair of snap ring pliers to get the rear shaft out of the brinn. I had mine turned down
    Feb 2008
    colchester il.
    2,172
    I repair/rebuild bert,brinns and falcons and the brinn is the better of the three to work on. as for turning down the out put shaft I turn them in my lathe using a carbide inserted radius tool to keep from weaking the shaft.
