2009 bms
Junior Member
Group: Members
2009 BMS (Belleville Motorsports) Intimidator Chevelle clip modified complete roller for sale. Frame is powdercoated black with white top deck and red body. This car has less than 40 races on it total. It sat in 2011 and only raced periodically other years. Current owner is original purchaser of car. in 2012 car was driven by Steve Dixon. Most parts on car are less than 12 races old. Currently set up as an Emod with quick change rear. Owner is willing to swap rear for brand new Ford 9" housing with pull bar mounts, axles, and pinion mount to make Econo Mod or IMCA legal for same price. Here is a list of parts on car: Tubular Chevelle lowers, Adjustable uppers, (4) Low friction ball joints, Pinto spindles, LW spring cups, US Brake front hubs with bearing spacers, US Brake metric calipers and pads, Brake guages, Brake adjuster, Quick Car gauges and master shutoff, (4) AFCO Edge base shock and 9010, (4) AFCO springs, RCI tear drop fuel cell (recently powdercoated), BSB Bearing birdcages, BSB LR bearing brake floater, BSB LR slider, Franklin LW quick change with 4:11 ring+pinion, Grand National 5x5 rear hubs, Adjustable pinion mount and frame mount, Adjustable J bar, AFCO pull bar, Bearing throttle pedel, Wilwood reverse mount pedels w/masters, AFCO radiator, Fuel filter and fuel lines, Battery cable, Optima battery, Shifter, BMS GM Midplate, Complete steel braided brake lines, 17" Kirkey seat with cover, (4) AERO wheels, (4) Hoosier tires, and more! This is a complete roller minus engine, tranny, bellhousing, and driveshaft. This car is in excellent shape and very clean! Priced for quick sale at $6995! Contact Joel at Close Racing Supply (814)225-3250 for more information and owners contact number. Car is located in Franklin, PA but can be in our shop in Eldred, PA for serious buyer.
new body
Originally Posted by IM2OLD2CARE
Junior Member
Group: Members
car now has new white body same price $6995.00
