Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21
    Dec 2012
    104
    Quote Originally Posted by James Hall #1 View Post
    Will do on the filter, had 3 different gages on it,,, same reading on all 3, cam towers are plugged. Cars is pretty quick, just no oil pressure.
    When your engine machinist pressure tested the block and head, did they pressure test the water passages like normal, or did they actually plug all the oil holes and pressure up the oil galleys?
  2. #22
    Sep 2009
    Leburn Kentucky
    30
    yes, new oil pump, even stretch the spring in one pump and it raised the pressure for just a few minutes and then dropped. The machinist plugged everything and pressured up the oil galleys in the head without the camshaft installed. I thought that they may have blocked the pressure off by doing that because the oil does travel throught the camshaft, right ? I'm off work tomorrow so I guess I'll check and recheck everything again, see if there something I've missed.
    [2012 Wince Mayabb Memorial outlaw 4-cyl. winner at 191 Speedway]
    [2010 Lucky 7 Speedway Outlaw 4 cyl. track record holder at 16.89]
    [2010 191 Speedway Outlaw 4 cyl. Showdown winner]
    Cubic inches doesn't mean alot,,, its what you do with what you got !!!!!!!!
