gear help for quick change
What size quick Change gear do I use for fayettr County Speedway I have a 08 shawl with the 406 Chevy small block and I want to get 8200 RP M's
631-639 should get u really close
if you have a 486 ring and pinion you will be close with the gear recomended if you have a 411 ring and pinion go up on that gear 40 to 50 points 680 or so.
differences between 4.11 and 4.86
not clamped up
I have been experiencing that as well, needing a little more gear with my new 4.11 winters QC. It has been about 40-50 points more than what guys are running with their 4.86 QC
What is this all about? any ideas?
dukesracin
Call franklin we wasted a couple of nights not knowing there is a difference,and I can't remember all of what they told us but we started using the right gears the problem goes away,and u also have to watch who you ask about gears there is alot more 411 gears than in the past.
