2010 bms roller--lots of parts for sale!!!
2010 BMS A mod roller. Currently 4 bar/4 bar but, can be set up any way wanted. Could also be converted to B mod easily. Candy Blue frame with white interior, deck and body. Steel brake lines with brake bias gauges, Chevelle clip, Afco springs, Hybrid rotors, IMCA pinto spindles, BMS MidPlate, new radiator, BMS rear end, 31 spline axles, BMS pullbar, BSB bearing birdcages, BSB brakefloater, BSB slider, 32 gallon fuel cell, new nice fuel line, new stainless fuel filter, BSB roller bearing gas pedal, Coleman brake and clutch pedals, new Ultrashield belts, AFCO guages (wt/op/fp), Procomp tach with remote recall, dual shifter with rods, MSD 6 AL box with high vibration coil, four wheels (one beadlock) and 4 good hoosiers.
Nice, straight car! $6800
Braswell alcohol carb-has not been run since completely rebuilt by Spanel, lots of new parts. Very nice piece! $1000 FIRM
Braswell alcohol carb rebuilt by Spanel at beginning of season. Works perfect! Starts every time with no pumping or babysitting while warming up. Best alcohol carb I've ever seen! $800
Brinn Trasmission-4 nights since freshened with complete Brinn rebuild kit. $1200 FIRM
Integra by W.A.R. modified shock package. Comes with Integra coil over kid. The only 4 shocks you need for all track conditions. $750
-Rocket Pullbar shock: $100
-2 heavy duty Afco JBars- $50 each
-PRP J bar-$50
-Afco single stage torque link with 1200# spring-27" center to center can have choice of springs: 900, 1200, 1450, progressive: $200
-900 # Afco torque link spring: $5
-1200# Afco torque link spring: $20
-1450 New Afco torque link spring: $30
-Progressive Hypercoil Spring: $20
-13" 175# Integra Spring NEW! $40
-650# 9x5" Integra Spring: $25
-600# 9x5" Integra Spring: $25
-700# 9x5" Hypercoil Spring: $5
-175# 16" Integra Spring: $25
-225# 16" Integra Spring NEW!: $50
-200# 13" Afco Spring: $20
-New Modified swedge tube tie rod assembly: $20
-5 single side 9" pinion plates: $15 for all 5
-2 double side 9" pinion plates: $10 for pair
-2 1" wheel spacers: $10 each
-1/2" wheel spacer: $5
-clamp on metric brake caliper bracket: $15
-RF Mud Cover-fits all 15" wheels: $20
-BSB 3090 COB-Left rear 9" shock: $100
-Integra coilover kit 4300 series: $25
-Integra coilover kit 4300 series: $40
-New black mesh window net and install kit: $35
-Lightweight 15" nylon fan blade, alcohol only!: $15
-2" inner mud plug: $10
-used 4" AFE Air Filter and black Outerwears with brand new top and bottom: $50
-14x4" AFE air filter: $15
-3.5" header turndown, NEW $15
-steel J Bar bracket, has radius holes: $20
-1.5" fuel filter brackets: $5
-Longacre tire bleed off kit with guage: $100
SHOENFELD 1186V HEADERS FOR MODIFIED. RIGHT SIDE IS ACTUALLY A 1162V9H (IS THE SAME LENGTH AS THE 1186V, BUT HAS BETTER PROTECTION AND ALLOWS FOR EASIER SPARK PLUG ACCESS). LEFT SIDE HAS A 90 DEGREE ELBOW AND A TURNDOWN. ALSO COMES WITH COPPER GASKETS AND 5/16" HEX HEAD BOLTS. THEY SHOULD FIT MOST CHASSIS BRANDS. THESE HEADERS ARE IN PERFECT CONDITION WITH VERY FEW NIGHTS. THEY ARE 1 3/4" TO 1 7/8" STEPPED. NOT LEGAL FOR A B-MOD.
$225 FIRM
LOCATED IN NORFOLK NEBRASKA
PLEASE CALLS TEXTS OR EMAILS ONLY!!!
402 750 8462
rossafrank@yahoo.com
