Results 1 to 7 of 7
    Oct 2012
    17
    Default Modifed Parts and Frame
    5 Composite Hypercoil Leaf Springs #200 #150 #175
    1 Steel Spring
    Lowering Blocks U Bolts and 1 set of Aluminum shackles
    $150.00
    1 9 inch Ford Rearend
    Housing - Floater
    Some Brackets on Housing
    No Hubs
    $100.00
    9 inch Ford Floater Complete Rearend
    Afco hubs
    4.71 Gear
    31 Spline Axles
    Brake Calipers and Lines
    60 inch Rearend
    Has Leaf Spring Clamp Pads
    $400.00
    Helmet blower
    $30.00
    9 inch Ford Floater Rearend
    Afco Snouts
    Some 4 Bar Brackets
    No hubs
    $50.00
    32 Gallon Tear Drop Fuel Cell
    32 Gallon Jazz Fuel Cell
    Complete and Cleaned Ready to Use
    $125.00
    2006 Buzzard Frame
    Chevelle Clip
    Leaf Spring Car
    Needs Frame Horns Fixed
    $350.00
    16 1/2 inch Kircky Seat With Red Cover
    Leg and Neck Brace
    $40.00
    30 over SRP Forged Domed Pistons for 6 inch rod 383 motor Part # SRP140348
    6 inch I Beam Eagle Sir Rods
    Barely used
    $200.00
    All Items Located Near Fort Loramie Ohio Contact 937-489-3706
    For Photos go to www.facebook.com and search angie carr rosenbeck photos will be posted under Modifed Parts and Frame
    Thanks for Looking!
    Apr 2009
    Marengo IN
    248
    Is the air pump sold or gone?
    Oct 2012
    17
    still have it
    Oct 2012
    17
    Ttt..........
    Jan 2013
    2
    Default tear drop
    sorry didn't think but is it in good shape or bent up
    hi I will buy the leaf springs, just tried calling and sent you a text., thanks !
    Feb 2011
    109
    Default Helmet Blower
    Would you take $30 for it shipped to Chesapeake, VA 23322?
    Josh
