2002 grt
2002 grt with winters rear-end, ppm bearing birdcages, 32gal. fuel-cell, app. rack, afco shocks and springs, gauges, pedal ass., shifter, used decking good shape, fiberglass roof, used md3 nose, new sides, hood, front filler, wilwood hubs and rotors, superlite brake calp., this is a complete roller less wheels and tires, motor, trans., seat, drive shaft, power sterring pump. the car has been repaired in front of cross member. Has orginal factory cross member and upper controll arm mounts. $2500.00 256-796-7173 or 256-339-9805
1800.00 without new sides, hood and nose filler.
