If you do run the 00308 I would suggest the 1.7/1.6 rocker combo...We went with this when Hendren suggested the cam...We played with some different rockers combo's on the dyno when we had the 360" built and that combo worked the best...
Before I can give you lobe numbers I need more information like carburetor size,stainless or titanium valves,rocker ratios,compression ratio,intake runner size,maximum rpm.
ok we have options since we are doing complete rebuild of the motor and are going to buy some new parts.
Perfconn- heads with be the motown 220 head with 64cc chambers, carb size will be eaither a 950 cfm or 750 cfm which we are in the process of building, we will run whatever carb works best for what track we are at. compression of the motor is close to 13 to 1, stainless steel valves, max rpm will be 7800. The engine will get a new victor jr or super jr intake manifold also we are using a 1 inc wilson manifold tapered billet spacer. the motor is on gas.
Went to the shop today and did some digging around and found a cam that we had in another one of our motors. And turns out its a comp cams 12-657-5 which has a lobe sep of 106, int/exh at 050" 256/262, valve lift of int/exh 0.549/0.543 and valve timing at 0.02. Was wonding if this is the cam we need and if so can we use it again with new lifter or do we need to get a new one with new lifters and all from comp? Do we need to get new rocker arms because we have 1.5 on both int/exh or do we get 1.6 or 1.7s?
We also have a 355 motor we are putting back together and going to be using some double hump heads that have been ported and polish. We are going to go with the 00308 cam from crower with that one. it seems like it will be a good combo to go with. With the 355 do we neeed to go with 1.6 or1.7 rockers as well or will 1.5 be fine.
thanks for the help guys.
Degree the intake lobe in on 102* and use a new set of lifters on the Comp 12-657-5
I wouldnt change the cam personally at first. I would change that God awful hurricane pos intake, and get a better carb. The Vic jr, or Super Vic will really change how that thing behaves in the upper rpm.
Originally Posted by propit21
sj dave-so you are saying that 00308 cam will work in a 383 with 220 worlds just fine. Do we need to run a 1.6/1.5 rocker combo or the 1.7/1.6 combo. Perfconn- do we need to get a special grind cam with the number you recommend because i can not find those number for any off the shelf cam. If so i read on here you perfer comp cams would that be the cam maker of choice. also what else beside the carb would we need to make sure we have to make that combo work. we have 1.5 rockers on both int/ext right now.let r eat- why is the hurrican manifold bad, ive heard ok things about them, don't mind getting a new manifold but just wondering what makes the victor jr so much betterwith the combo we have now are we overflowing what our motor can do at lower rpms? If i understand correctly we are not producing any torque at lower rpm with the motor combo we have because it flows to much fuel and air and not getting rid of it fast enough unless we turn more rpm's?
The cross section on the Hurricane is too large. Made for drag racing. Also its not good in stock form.
BUCKLE UP NOW, YA HEAR?
i know am bringing this up again just wanting to learn and get what will work the best. Here is a cam spec that i have been looking at and wondering what might be the result of running on our engine set up. Again this a is a 3000 lbs superstock 3 link car on gas, motor is a 383 with lightwight bottom end, 6 inch rods, 7 cc domes with 220 world motown heads, going to get a super victor or the one inch taller one and it will be either on a 950 cfm hp holley or 750 cfm hp holley. 7800 rpm chip rule, track is normal dry and dusty for the main tight corner 3/8mile track.
cam specs
duration at .050 int 258/ext 262
valve lift int .570/ext 5.80 thats with 1.5 rockers but will more then likely run 1.6 on the intake?
lobe center 106*
ADV duration int 286*/ext 290*
@ .050
intake open 23 btdc exhaust open 57 bbdc
intake close 55 abdc exhaust close 25 atdc
Propit21- I would take Terry's advise and not limit yourself to an "ok" cam rather then the cam that will do what your motor needs. As Ego and others said get a 2925 intake and a 2" HVH super sucker. Your runnin WCSS rules right?
»»*†HÀ†§ HÓ††™««
Yes we run wuss rules. This cam is real close to what he recommends I believe. This is an isky camshaft. We have a real nice Wilson manifold tapered spacer already. What makes the super victor so much better then the hurricane. Just want to make the right decisions and not keep spending money for unneeded parts.
The 2925 has a smaller CSA with longer runners than the Hurricane. Will work better on a circle track deal almost always...
Originally Posted by let-r-eat
All the bigger heads are going to do is RAISE the peak HP rpm and/or pk torque rpm. There is no crutching that with a cam. Some think so but all your doing is cutting back the duration and killing where the heads were made to run even more.There is no substitute for having the proper heads for the cubes/rpm range of the engine.If your going out there and dropping down to 3500 rpms in the corners and you have monster heads you're just defeating the purpose. You need a combination. Everything works together.
This is the truth, the whole truth and nothing but the truth. COMBINATION.
You first weigh any restrictions, such as carb size or RPM limitations. You then find or make a port, valve and head angle that will make a useable horsepower curve. You then pick a cam and carb to fit the needs of these. When you start tweaking with cams, timing or carbs that where not meant for the combination, you will always lose something for anything you gain. This usually makes your power curve shorter in duration or lower on power. This is why a good head porter gets the big bucks.
With this said, you sometimes can add to the top end of your power curve at the cost of the bottom. There is no free horsepower. The real trick is getting a good curve and gearing for it.
Thanks guys, yes I wish we could have a little better combo for the motor but this is what we have and trying to make the best out of it. With that we are on a 7800 rpm chip rule so I know we are limited a little with the heads we have. If I understand right the shorter duration will bring the peak power down in the rpm. The isky cam is installed straight up so it will be at 106 intake centerline. And the lobe is also 106. How much would a wider lsa help bring the rpm range down.
A little update, got the motors together by the engine guy. BTW looking for a good engine shop person in southern california, we are sick and tired of the guy we are using. Went with a isky cam for the 383 the cam 201571. Would recommend isky racing cams to anyone looking for a new cam or valve train part. What a stand up company the customer service is the best you are ever going to get, Ron Iskenderian himself helped us on the phone for like 2 hours called our engine guy himself to explain so issue we were having with the valve springs and gave us a great deal on a new set of spring since we got the wrong ones. Awesome company can't say it enough if you need any valve train part go with ISKY.
Anyway haven't ran the motors yet just picked them up but our hardheaded engine guy said the cam we choose which is the 201571 isn't enough cam for our motor and its to small.
cam specs
lobe center 106*
@ .050
Our engine guy tells me i don't know what am talking about and that the motor is going to lay down on power for us. I am going on what i ve been told here and the little ive been learning about cams. I have called isky and asked them about the cam and they agree it should work just great and should be happy with it. Just looking for a little reinsurance that we made the right choice in cams. Again its a 383 with light weight internals, 6 inch rods 7 cc domes, world motown 220 heads, hurrican intake with the isky valve train.
Our engine builder then went ahead and assamble our 355 back up motor witha cam that he had that he said will be better then what we have in the 383 yet he won't tell us what he put in the motor. the only thing he told us was valve lash setting and it had more lift then the isky cam. the 355 motor has double hump 2.02 64cc chamber heads ported and polish heads with victor jr intake, 6 inch rods with 7 cc domes. What is everyone opinion on this should we just run it and see how it runs or try and find our what cam he put in it. Long story short we are looking for a new engine guys.
Thanks for listining
Propit21: The thing I must ask is...WHY did you not do what these guys told you too and trash the Hurrican Intake. ???These guys give good advice for free and if folks dont listen they wont keep giving it to you when you ask them again. And your engine guy may be right, the 355 may run better as long as you keep using the wrong intake on the 383. NOW: If my engine guy would not tell me what he put in my engine, all I can say is SEE-YA......Hes a joke don't go back.
I know I agree with all of you I do. I believe we will change it soon but it was just one more expense right now of a high $$ bill. We figure when can change the intake out a little later on. Should we go with victor jr, or super victor.
Super victor 2925 all the way. I know some engine builders keep cams a secret just like car owners will allow tear downs until is involves the cam as long as it is of legal nature. Cams are a huge part in what makes an engine do what it does and many once they find "the one" are not willing to let that info out. However if my builder tried keeping it a secret we would have a huge talk or I would go someplace else as well...
»»*†HÀ†§ HÓ††™««
