Results 1 to 14 of 14
    Aug 2011
    544
    Default Steel swage tube strength?
    I had a problem last year with breaking front speedway brand swage tubes. Are the afcos or allstar brands any stronger? I know afco is owned by speedway but didn't know if there was a difference. I'm 100% sure the problem was from playing bumper cars "LOL" so I just need some input. Also what brand inner tierod is everyone using.
    DeWitt IA
    414
    I build DOM tubes they will not brake like the swedge tube .I have sizes 4 1/2 - 18'' long instock and can make custom tubes aswell . MADE IN THE U.S.A tubing .
    Aug 2011
    544
    Whats the price on two 11" bars.
    DeWitt IA
    414
    Feb 2008
    colchester il.
    2,172
    swedge tubes are weaker by design. they heat the metal up once it's at temp. they put it in a press with a die and mandral to press it in to the size and shape. after that it goes to a threading operation. 9 times out of ten they break right behind the heated area. now you throw in the speedway/afco tubes are being made in china with cheap metal. I like many other's build and sell parts to local racers as well as racers online across the country and some overseas.
    performance advantage
    colchester il. 62326
    Aug 2011
    544
    I'm slowly learning you save 3 or 4 bucks here and there and its costing me a TON more in the long run. Especially considering every time something breaks or fails I have to by it again.
    tulsa america
    2,687
    Quote Originally Posted by jsf74 View Post
    I think the big loss would be when you are battling for the lead and one breaks. That $3-4 part just cost u 200-500
    Colstrip,MT
    351
    You are right about playing "bumper cars" , never underestamate any contact.
    one idea is better have it break the first weak link, then deeper into the car.
    You can build your own out of 3/4 dom steering tubing, 5/8 tap drill, LH &RH fine thread taps.
    Aug 2011
    544
    Battling for the lead that's funny. I'm just trying to run mid pack for now.
  10. #10
    Nov 2010
    Lock Haven, Pa
    664
    I use chrome moly tubes
  11. #11
    I use the chromoly rods from Day Motorsports , they have lived through some pretty heavy contact.
  12. #12
    Jun 2007
    796
    The swedge tubes from performance bodies are good. Dont use swedge tubes on a pullbar, they will break and hurt you. Especially on long pullbars.Use the 3/16 wall tap tube.
  13. #13
    Apr 2009
    Marengo IN
    247
    Broke a tube on a pullbar once.......wow was that costly!
  14. #14
    Nov 2013
    Canada
    137
    Throw away swedge tube.
