Results 1 to 4 of 4
Thread: usra b mod ?
    Default usra b mod ?
    what is the rule on the pullbar does it have to be solid or a spring i can not find it in the rules
    Nov 2010
    21
    you can run a spring or biscut onless u run a aftermarket trans like a bert then you have to run a solid pull bar
    what would be better to run a spring or biscut with sliders
    if you go to a springbar from a solid pullbar do you run the same angle in it and do i need to change springs and shocks
