Results 1 to 4 of 4
    686
    Default 2008 Turn key shaw modified
    SOLD..................
    Headed to Oregon
    I have a 2008 Shaw modified I took on trade. Has only been run a handful of times since 2010. Chevelle frame. 1.75 cage
    Looking to trade for 604 crate late model
    May consider other trades?
    8500.00
    New black body and deck.
    Lazer lid fiberglass roof
    Stock lower a frames with greasable bushings. Shaw adjustable uppers. Afco swiveler cup weight jacks. Howe upper and lower ball joints.
    QA1 rebuildable shocks
    Winters quick change rearend. Have 9 inch floater and axles that also go with car.
    Set up on pull bar with progressive spring. LR brake floater option. Outpace 4 bars.TWM bearing sliders
    22 gallon cell
    Coleman gas pedal,Wilwood brake and clutch assembly,OP,WT,FP gages,sweet splined steering coupler, Kirkey seat,RCI belts
    Optima battery ,electric shut off switch, MSD 6AL ignition and MSD coil
    Falcon transmission
    Like new radiator.
    383 Motor
    350 -010 block.After market billet 4 bolt center caps. Eagle 4340 crank. Scat H beam rods.Champ pans CP100LT. MSD distr.
    Pro top line steel heads. Same as RHS 12333-01. 200cc with 50 cc chamber.PRW roller rockers and stud girdle.
    Comp Cams roller cam # 12-902-9 and roller lifters.CV fuel pump.Holley intake. 1" carb spacer. Holley 4 barrell with billet metering plates and base.
    PBM damper.Aluminum water pump.PS pump with attached tank.Serpentine belt pulleys. CVR protorque starter.Schoenfeld headers.
    glnrcg@netzero.com
    686
    Added some pics. Just about finished with new body.
    686
    Nice car. Ready for new home. Motor built by Jeffs Performance in Sherman Texas
    Apr 2009
    332
    Where are you located?
