420whp 355 fresh!
i have a completley rbuilt at the start of the season, a built 355 it was dynoed at 420whp, it has scat crank, speed-pro rods, speed-pro pistons flat tops(with valve releaf), flat tappett cam 500+ lift( cant think off the top of my head), world product heads( 208 valves, port and polish, angle plugs), "stock" looking intake driled a rounded courners for better flow( ads and extra 90hp! on the dyno), new bearings, new seals, four bolt main, high nickle block. i also have a built th350 that was paired with it it has redline cluthes, stage 2 shift kit hits hard, the motor has about 30 laps on it, the reason for want to trade is the class just got to much money. i value my motor at 3500 or more plus the tranny, i do have way more money in this motor then $3500 so keep that in mind when you offer thank you.
you can contact me at 5132123685 (text anytime call after 3:30)
