UMP Modified Parts Sellout UPDATED LIST
Shaun Scheerbaum
724-316-4554
sscheerbaum@verizon.net
All prices less shipping from western PA at buyer's expense. Thanks for looking!
2 E-mod rear bumper. 2 piece Rocket-style. $20.00ea
1 Butler Built 16" seat. Good cond. $50.00
1 Steering wheel pad. Like new. $5.00
1 15" wheel. Good cond. $25.00
1 Splined quick release steering wheel hub. Good cond. Shaft adapter not included. $20.00
3 Hex quick release steering wheel hub. Good cond. Shaft adapter not included. $5.00ea
2 D&M Machine 2:1 steering quickener. Good cond. $45.00ea
3 Rear end fill can. Good cond. $10.00ea
1 Set small block chevy front motor mount brackets. Good cond. $20.00
1 Set small block chevy rear motor mount brackets. Good con. $20.00
2 2 lever shifter. Good cond. $25.00ea
1 JAZ 32 gal cell with custom tube cage. 26 1/2 x 18 x 18. Very good cond. $100.00
2 1 1/2" Aluminum bolt on shock brackets. Good cond. $5.00ea
1 Fuel filter, 10" with paper element, good cond. $10.00
3 2" fuel filter bracket for 1 1/2" tube. Good cond. $5.00ea
1 2" fuel filter bracket for 1 1/4" tube. Good cond. $5.00
1 Axle, 31 sp gun-drilled, 35", good cond. $25.00
1 Axle, 31 sp gun-drilled, 31", good cond. $25.00
1 Axle, 31 sp gun-drilled, 33 1/2", good cond. $25.00
1 Axle, 31 sp gun-drilled, 27", good cond. $25.00
1 Driveshaft, 33", new u-joints, just balanced, with 5" slip yoke, like new cond. $100.00
1 Driveshaft, 33", new u-joints, just balanced, with 6" slip yoke, like new cond. $110.00
1 Driveshaft, 33", with u-joints and 3 1/2" slip yoke $40.00
1 Metric steering box, good cond. $50.00
1 Pull bar bracket, aluminum bolt in, for 1 5/8" tube. Good cond. $20.00
2 13" x 5" Afco 250# spring, good cond. $20.00
1 13" x 5" Afco 200# spring, good cond. $20.00
2 13" x 5" Afco 275# spring, good cond. $20.00ea
1 13" x 5" Afco 225# spring, good cond. $20.00
1 11" x 5" Afco 200# spring, good cond. $20.00
1 9" x 5 1/2" Hypercoil 750# spring, good cond. $20.00
1 9" x 5 1/2" Afco 650# spring, good cond. $20.00
2 9" x 5" Afco 550# spring, good cond. $20.00ea
3 9" x 5" Afco 650# spring, good cond $20.00ea
1 9" x 5" Afco 800# spring, good cond. $20.00
1 9" x 5" Afco 750# spring, good cond. $20.00
2 9" x 5" Afco 500# spring, good cond. $20.00ea
1 9" x 5" Hypercoil 750# spring, good cond. $20.00
1 9" x 5" Hypercoil 700# spring, good cond. $20.00
1 9" x 5" Hypercoil 600# spring, good cond. $20.00
1 9" Ford 5.43 full spool with stainless crush sleeve. Professionally built. Less than 5 races since freshened. $300.00
1 9" Ford 5.43 full spool. Came with a buyout and was never used. Appears to be in good cond. $200.00
1 9" Ford 5.67 full spool with stainless crush sleeve. Professionally built. Just freshened. $300.00
1 60" Rearend, 31 spline, 1" offset, with pullbar and 3 link brackets, new 5x5 GN hubs/rotors, caliper brackets, & axle seals. $400.00
1 Aluminum pinion plate for 9", double sided with threaded height adjusters on each side. Fair cond. $10.00
1 Pro Shocks custom steel 0-0 9" LR in front with 2" extender and screw on ends. Like new. $50.00
1 Ultra Shield sprint style window net with extender for use on full bodied cars. Never used. $30.00
2 Big Chevy hub/rotor complete with bearings. Good cond. $25.00ea
2 Metric center link. Good cond. $10.00ea
1 Ball joint reamer 10 degree - 2" / foot. Used twice. $50.00
1 Metric spindle checker. Like new $25.00
1 Chevelle RH spindle. Good cond. $45.00
1 Chevelle LH spindle. Good cond. $45.00
1 Allstar 56208 bolt-in upper BJ. Fits Impala, Camaro and Chevelle spindles. Never used. $10.00
2 Allstar 56204 bolt-in upper BJ. Fits Impala and Pinto spidles. Never used. $10.00ea
2 Allstar 56212 press-in lower BJ. Fits Impala spindles. $10.00ea
1 US Brake 9851-8521 rotor seal. Fits pinto spindle hybrid rotors and '79 and up metric. Never used. $5.00
1 8 3/4" Offset LH Upper Control Arm with Allstar 56204 bolt-in upper BJ. Like new. $50.00
1 Afco 8 3/4" Offset RH Upper Control Arm. Good cond. $40.00
1 Ruhlman 8 1/2" Offset RH Upper Control Arm. Angled screw in BJ. Good cond. $35.00
1 Ruhlman style 11" Offset LH Upper Control Arm. Split, bolt in BJ. Good cond. $40.00
1 Speedway Motors Chevelle LF lower control arm with spacer kit and 5651 BJ for Pinto or Chevelle spindle. Like new. $70.00
2 Stock Chevelle LF lower control arm with 5651 BJ for Pinto or Chevelle spindle and shock mount. Good cond. $50.00ea
1 Moroso 65042 Throttle Stop. Fits Holley 4150. Never used. $10.00
1 Speedway 135-61 2" carb stud kit. Never used. $1.00
1 TurboStart 16V battery charger. Very good condition. $100.00
1 MSD Baster High Vibration Coil. Like new. $35.00
1 MSD 6AL-2 Ignition Box. Like new. $125.00
1 MSD 8823 - 6 series box vibration mounts. Never used. $5.00
