Results 1 to 10 of 10
Thread: body ?
    Default body ?
    how does everyone build the slope in the roofs on a modified
    796
    If your asking how to bend it.Its a sheet metal crimping tool.You only need to slightly slope the front 4 inches or so and rest back flat..
    The way i have always done this is by breaking the driver side and passenger side to approx 45 degree angle. What gives you the curve is by using a crimping tool. As you crimp the bent edge, it will give you a radius.
    http://eastwesthydro.com/garden-supp...5-blade-700840
    This something similar that i use. It has three blades on one and two on the other side.
    I hope this helps
    in a van down by the river
    1,892
    Default roof
    I build a flat roof. more downforce. and since they allow 3" of rake, it really adds downforce.
    what gauge aluminum is to light
    Jan 2008
    121
    Default Aluminum
    0.032 is very flimsy. Most use 0.040.
    Travis
    Oct 2010
    422
    Curved roofs are better with spoilers, it directs the air to the spoiler better.
    Apr 2009
    Marengo IN
    247
    MM90 is right.
    1,892
    Default air
    Quote Originally Posted by MM90 View Post
    Their is no way that air from the roof gets down to the spoiler with enough force to do anything. the spoiler gets its air off the deck. If you have that much curve in your roof, you are creating lift, or alot of turbulant air that will not produce downforce.
    If you had a front window, and a rear window yes, but not with a tunneled body.
  10. #10
    Jul 2007
    558
    theres a very good article either in circle track or dirt modified magazine i cant remember which right now that kyle strickler did about bodies. I would read it. Maybe someone on here can link to it, im at work otherwise i could tell you what to look for.
    Chris Zogg
