I have 2 sets of cyl heads, !st set is the bowtie 034 that I can run a roller cam with, and the 2nd set is the new vortec 2 inch intake heads that I can run a solid lift cam with. Which combination would yall recommend, bottom end will be the same regardless which heads I run. 2300 pound limited late on a 3/8 momentum style track. Thanks for any input.
