Just opened up a box of sealed power rings for SBC. The top ring has no taper or marking. Anyone have a clue?
Rings should've came with a set of instructions, but generally rings with no dimple or taper, can be installed either way.
Josh K.
Soundss like you have a set of cast rings.
CNC so are these junk? I called Fed Mogul and they said they were packaged wrong. Should be a dot and a taper.
The ones that are not marked are square cut and can go either direction.
Old enuf to know better, still too young to givadamm.
