Results 1 to 6 of 6
    144
    Default Aluminum Ford Windsor heads.
    I am rebuilding a Ford 358 based on a 69 Windsor block, i had previously ran it with a set of Roush World 200 Iron heads that had 2.02/1.60 valves 64cc combustion chambers, I want to get a set of aluminum heads that will bolt right on, allow me to use the Edelbrock Victor JR intake I have and the same headers that I used. I have found several sets of heads around but is seems like none are capable of using the big cam that I have. The lift is nearly .730. and of course the will be on an engine spinning more than 7500 rpm. If you have or no someone who may have a set please contact me on here.
    144
    Back to the top
    I hear Yates heads are pretty good. Did you get rid of the roush heads?
    144
    Still have the Roush heads, looks like I might be using them if I can't find a decent set of aluminum heads that work with my Edelbrock Victor Jr. intake.
    Jun 2007
    671
    Try Mullins, they were building Fords the last that I knew.
    144
    I will thanks!
