Results 1 to 7 of 7
Thread: birdcages
    Oct 2011
    20
    Default birdcages
    could someone please explain to me how placement of birdcages effect handling of the car like side to side on axle tube and indexing forward and rearward?? Iv seen alot that are mounted closer to the center of rearend and I put new 4 bar brackets in my car (with no help really from chassis builder) and it was z link on rr and switched to 4 bar but the birdcages are out pretty far on axletube (i lined up new mounts inline with old z link mount and Im not sure what the birdcages out so far on axle will do) thanks
    Sep 2009
    indiana
    97
    the farther out on the axle = more weight to that tire but less rear steer movement.
    Shoebox is correct. It takes 200# to compress a 200#spring 1 inch. That said - my theory is that as you move the spring outboard it is more effective (to me that is stiffer). If you move it inboard it becomes less effective (softer). It is all about leverage. Hopefully someone that is more learned will explain this theory better.
    Aug 2011
    1,774
    Quote Originally Posted by hasben View Post
    Like a nova vs a camaro. Closer to centerline, more roll.
    Oct 2011
    20
    thanks guys so should i move my birdcages in or leave them i have no clue where they should be from the start when we got the car it was so screwed up that i had absolutly nothing to go off of
    Nov 2010
    Lock Haven, Pa
    664
    Run them so the bars are slightly toed in at the front.
    Jun 2009
    358
    Alot are set to have the bars pointing strait ahead,then use heim spacers on chassis so the top links to point slightly toward the center of car.
