Check it out!!! Huge parts list!!! MORE PARTS ADDED!!!
HUGE PARTS LIST (Engine parts, Shocks, Headers, Wheels,
Carbs, and Safety Equip. ETC....)
CHECK IT OUT!!!
1)Brinn Starter $150
2)Peterson Single Stage External Oil Pump SOLD!!!
3)Bowtie CNC Block 4.145 bore 350 mains SOLD!!!
4)Bowtie CNC Block 4.010 bore 350 mains SOLD!!!
5)Bowtie Heads Early Version Stage 1 Heads with Bigger
Intake Runners NO PORT WORK 2.05 Int. 1.6 Ext. Stainless
Steel Valves Isky Goldstripe Toolroom Springs SOLD!!!
6)Bowtie Victor Jr. Intake Fully Ported $300
7)Comp Cam Timing Belt Setup SOLD!!!
8)Stainless Steel Tri-Y Ford Headers for Rocket Chassis
SOLD!!!
9)Beyea 4 into 1 SBC 602 crate Headers mild steel for Dirt Late
Model BRAND NEW $500 new asking $350
10)Beyea SBC Tri-Y fit Dart, Bowtie, and SBC aluminum
SPEC Heads for Dirt Late Model mild steel 8 nights on
them like new SOLD!!!
11)Stiles SBC 4 into 1 fit Dart, Bowtie, and SBC aluminum
SPEC Heads for Dirt Late Model mild steel SOLD!!!
12)Stiles Ford Right Side Stainless Steel Tri-Y Header for
Dirt Late Model $350
13)Stealth 1.420" Gas Carb Raced 8 times since Freshened
SOLD!!!
14)Stealth Gas Carb 390 cfm $500
15)Jesel SBC Rocker Arms 1.6 Int. 1.5 Ext. Shotpeened
Bodies with stands (8 races old)and complete spare set of
Rockers with Shafts fit Dart steel heads, Motown, Bowties,
and SBC aluminum SPEC Heads ($1700 new without spare set)
SOLD!!!
16)Crower Severe Duty Cut Away Roller Lifters for SBC .840
$200
17)Crower Severe Duty Roller Lifters Tall for SBC .840
$200
18)Isky Roller Lifters Tall for SBC .840 $200
19)Isky SBC Valve Springs Part No. 9385 Brand New $150
20)T&D SC1 Aluminum Cornett Stands with Rocker Arm Studs
$200
21)(8) Ferrea 1.6 Comp. Plus Stainless Steel Ext. Valves
SBC 11/32 Stem .050 long $80
22)SBC Lifter Valley Tray $35
23)CV Products Ford Billet Fuel Pump $150
24)KRC Bellhousing Mount PS pump/Pulley with Bracket &
Spacers SOLD!!!
25)KRC Aluminum Tandem PS Pump Hex Drive $200
26)MSD Cap-A-Dapt $20
27)Wilwood Wide 5 drive flange LW Silver Like New SOLD!!!
28)Barry Grant SBC Fuel Pump HP16 SOLD!!!
29)Holley Fuel Pressure Regulator $20
30)KSE to Oil Pump direct tandem mount adapter SOLD!!!
31)KSE bellhousing mount adapter $20
32)Steering Wheel Center Pad $10
33)Aero LR Inner Mud Cover Wide 5 (5" offset) Part# 500015
New $15
34)(4) Willy's Quick Release Carb Fittings Part# 7502 $20
for all
35)Sternum Protector adapter for safety belts $10
36)Liquid Filled Tire Pressure Gauge 30# with 14" hose &
bleeder $30
37)Zero Hyperglow in the dark oil temp gauge 280 deg. $15
38)Zero Hyperglow in the dark water temp gauge 280 deg.
SOLD!!!
39)Fuel Filter 1.5" Clamp Bracket $5
40)16v Turbo Start Battery Charger (Quit Working) $50
41)SBC Baker Engines Pro Cam Wet Sump Circle Track Oil Pan
SOLD!!!
42)SBC Steel Wet Sump Circle Track Oil Pan (Box Style) $50
43)Moroso Tall Die Cast Aluminum SBC Valve Covers SOLD!!!
44)PPM Double Sided J-Bar Quickchange Mount SOLD!!!
45)PPM Double J-Bar Frame Mount (1) Black (1) Aluminum SOLD!!!
46)Holley Carb Fuel Log SOLD!!!
47)Bert Shifter Linkage with Clevis $20
48)Ford Head Mount PS Bracket $25
49)Weight Clamps (4) 1.25" (2) 2" square $7 each
50)All-star Steering Wheel Disconnect Part#52302 New in
package SOLD!!!
51)Rayburn Aluminum Pull Bar 13" $50
52)Bert Ford Flywheel with HTD drive $100
53)Brinn Ford Aluminum HTD Flywheel $250
54)Wehrs Shock Cannister Clamp 1.75" $20
55)PPM Shock Cannister Clamp 1.75 $20
56)Catch-It-Cam (Brand New) $250
57)Sweet Dual Power Integrated Rack 18.25" 4.0 .210 servo $600
58)Sweet Rack Shaft (Brand New) Part# 908-21011 16 7/16"
$60
59)Sweet Double Pull Power Rack Cylinder 1.5" body 16"
long $125
60)LF & RF Mastersbilt Smack Spindles (used) $75 each
61)Crower Rev Kit $100
62)Crane Rev Kit $100
63)SBC Head Stud Kit SOLD!!!
64)Integra Cannister Shocks by CMD (Mars) Double
Adjustable with coilover kits (LF,RF,LR,RR) SOLD!!!
65)Integra Cannister Shock RF Double Adjustable (Brand
New) SOLD!!!
66)Integra LRF Big Bleed (non-adjustable) Shock SOLD!!!
67)Advanced Racing Suspension Cannister Shocks
Double-Adjustable (LF,RF,LR,RR) SOLD!!!
68)Ohlins Cannister LMJ Shocks by Precision Performance
(Andy Eckrich) Double-Adjustable with coilover kits
(LF,RF,LR w/2"ext.,RR) SOLD!!!
69)Integra IDA's by Precision Performance with coilover
kits (LF,RF,LR,RR) Bought new from GW(ran 12 nights) Had
Andy ReValve & Freshen (Ran 9 nights since) SOLD!!!
70)Integra 5th Coil Shock by Precision Performance Rebound
Adjustable SOLD!!!
71)Moroso Plug Wires SOLD!!!
72)Simpson Sprint Car Style Window Net with Ratchet $25
73)Simpson 5 point belts (used) $30
74)Custom Made Fiberglass Air Cleaner Bottom for Cold Air
from Nose Piece Never Used ($500 New) asking $175
75)Real 14" Wheels 5" offset Beadlocks $175 each
Non-Beadlocks $125 each
76)Duralite 14" Wheels 5" offset Non-Beadlocks $125 each
77)Duralite Aluminum Wheel Covers $15 each
78)Fastshaft 2" Chrome Moly Light Weight Driveshaft (No
Slip Yoke) 35" long $150
79)Lead Ballast $1 per pound SOLD!!!
80) Bilstein Steel Body Shocks 7" 70/30 9" 30/30 $50 each
81)(NEW)MSD HVC II Blue Coil Part# 8253 $140
82)(NEW)LONGACRE 61016 Coilover Spring Rubber (orange) $20
83)(NEW)LONGACRE 61041 Coilover Spring Rubber (RED) $20
84)(NEW)ALLSTAR Brake Bias Gauges Part# 80170 SOLD!!!
85)Power Master XS Torque Reverse Mount Starter $150
86)MSD 6ALN 6430 Box SOLD!!!
87)SBC 1" Water Neck Riser Block with Fittings & Hoses SOLD!!!
88)MASON RACIN Reverse Mount Starter $150
89)Dynatech Mod Step Headers Coated Part# 01-16501LR 33048
$140
90)Dynatech Mod Step Headers Part# 01-16501LR 33048 $100
91)1" Aluminum Super Sucker Carb Spacer SOLD!!!
92)Blue Anodized Aluminum Fuel Log SOLD!!!
93)(LIKE NEW)MSD Dist. 85551 Bronze Gear Small Cap & Moroso
Blue Max Wires SOLD!!!
94)Jaz Crankcase Breather Tank $25
95)Autometer 3.75 Tach Remote Recall SOLD!!!
96)Quickcar 5" Recall Tach $75
97)Quickcar Fuel Pressure Gauge SOLD!!!
98)Sweet 12 to 1 Steering Box $375
99)Afco 2 to 1 Steering Quickner SOLD!!!
100)4.86 9" 3rd member Lightened Ring Gear and Light
Weight Full Spool $375
101)5.00 9" 3rd member Lightened Ring Gear and Light
102)5.14 9" 3rd member Lightened Ring Gear and Light
Weight Full Spool SOLD!!!
103)5.48 9" 3rd member Lightened Ring Gear and Light
ALL PRICES ARE NEGOTIABLE AND DO NOT INCLUDE SHIPPING
COSTS!!!
CALL FOR MORE INFO THANKS!!
David (712) 779-0116 cell
Chris (712) 779-0304 cell
parts
could you send some pictures of your water temp gauge to bnrmotorsports98@gmail.com? thanks.
Can you please send me pics of the water temp gauge to cparsons1@new.rr.com Thanks Clint 920-360-2033
We are located in SW Iowa. The other guy is gonna buy the water temp gauge. Thanks
tttttttttttttttttttttttttttttttttt
how many psi is the fuel pump and is it for gas and can you send me pics of the raised water neck with fittings. Send to cparsons1@new.rr.com. Thanks Clint 920-360-2033
Barry grant fuel pump SOLD!!! THANKS!
Do you have part numbers for the blocks? I need to know what max bore is on them.
parts
