New to SS
New to street stock and looking for some ride height information. Where are you checking it at and how tall is is supposed to be. It's a metric chassis. Thanks guys/gals!!
ride hieght
if its a metric,,check it where the frame comes level with the ground,just behind the front tires and just fwd of the rears....i found that setting the front lower a-arms level from inside bolt to the ball of the balljoint works..then set the rear of the car about 1 inch higher...if you need less sidebite,then lean the whole car to the drivers side
