775HP 412 All Aluminum SB2
Aluminum Dart Block/SB2 Head 412 dirt late model engine. 4.155 (+.030) bore x 3.8 stroke. Dart aluminum block, SCAT 4340 lightweight profiled crankshaft, Manley Pro 4340 rods, JE Pistons, Comp Cams roller cam, Finish First Racing Heads, fabricated aluminum dry sump pan. Pro Pan valve covers, Marx 950 Holley, HVH carb spacer, lightweight water pump and pulleys, Coated Beyea Tri-Y headers, Stock Car Products 4 stage dry sump pump. T&D Machine rockers just back from T&D factory reman. Dyno'd by Mike Mullvain March 2011 at 775hp/630tq. New low end cam installed by Matt Rhyne in March 2012. 440 laps since rings/bearings. Well maintained, not worn out or abused. Fresh Brad Penn 20W-50 oil and valve adj. every other night. Was Mike Mullvain's personal engine. $11,500 309-2five8-8288. Peoria.
https://picasaweb.google.com/1133247...31326570481266
Would you sell just the headers? If so how much?
New plugwires and clamps...
Thanks for the response...
