Results 1 to 2 of 2
Thread: tight
    Default tight
    i have a usra b mod that has good drive off but just a little tight getting in and center and does not really roll over on the right side it has a j bar even with pinion and 5 3\4 rake what would moving it up on pinion side do this is a 9in every thing i read said to allways run it even with pinion or would lowering it on the chassis side be better
    My first thought would be drive it in a little deeper. If you have tried that, as well as changing your entry line, I would drop the j-bar on the frame a little. The frame change will have less effect on the corner than moving it on the pinion.
