best induction?
Looking for the best carb,spacer, intake and head combo for this motor?
Porting is allowed if needed. gasoline, and or a race fuel allowed. 540/560 max cam lift rule. headers allowed. slight restriction with running mufflers ahead of rear end.
357ci, 9.5:1 ratio. 4 barrel, short track(1/4-3/8 dirt oval tacky, light dry slick),top of spacer must be no more than 7" from top rear of block. Unsure what cam im putting in it yet. 2800 lbs metric car
steel head, 23 degree, 7000 rpm pill
let-r-eat
vortec bowtie.
X2........
agreed in less u can find a good deal on a set of 200 and smaller darts or rhs heads 650 double pumper quick fuel carb if u got the money and at least a wilson brothers spacer with a air gep rpm intake with it gaskit matched up the runner til the runners turn and port match the head just remember big runner dont always help and idk if u can get the compression down that low with those bowtie heads ud have to check and call lunati for a cam
jared flower
pump gas no need for race fuel with that low compression
jared flower
