WOW! $700 to win Mini Stocks @TENN National SAT. SEPT. 14th
Bring Em' ON! MINISTOCK MANIA (Summer Shootout #4) $700 to win!
During the Tennessee "Fall Nationals" on Saturday, September 14th
TENNESSEE NATIONAL RACEWAY - Hohenwald, TN
1. USCS Outlaw Thunder Tour Winged Sprint Cars $2000 to win
2. Mini Stock Mania (Summer Shootout race #4) $700 to win!
3. Limited Late Models $1000 to win!
4. Modified Street $300 to win
5. E-MODs $300 to win
6. plus...Dwarf Cars $200 to win!
For Mini Stock Summer Shootout and TN National class rules and info please visit www.racetn.com . For USCS rules, etc. please visit www.uscsracing.com or call 770-865-6097
Tennessee National Raceway
MINI STOCK TECHNICAL RULES 2013
1. BODIES: 1971- 2004.
Any compact or sub-compact front or rear wheel drive must have full stock body, firewall and floor plan.
No sports cars, vans, or convertibles.
Trucks are permitted: must be all stock for that vehicle.
No extended cab or long bed truck.
All parts on racecar must be stock except where noted. Any infraction may require weight penalty.
After market hoods and bumpers ok.
Radiator protection bar must not be forward of the bumper.
Bumpers do not have to be stock, but must not be wider than the fenders.
Rear spoilers - ok, 8 maximum.
Front and rear wrecker hooks are mandatory, but must not extend past bumper.
(not a nice word)(not a nice word)(not a nice word)(not a nice word)pit style interior and skirting are permitted.
Frames: Unibody must be reinforced - MANDATORY.
Racing seat, harness, window net, fire ext. fuel cell, three 3/8 rods in front of driver, full fire suit, and
approved helmet. (Required at all times)
2. SUSPENSION: must be stock type.
After market type springs and shocks ok. Must be in stock location.
Alternations of upper or lower control arms and spring buckets are not permitted.
Cars with leaf springs may have adjustable shackled- sliders on each leaf spring.
Jack bolts all four corners will be allowed.
3. WHEELS: Steel - 8 width max. Off set permitted.
Bead locks-right side only but not mandatory.
4. TIRES: 8 60 series street radials only. No racing tires, recaps, etc. No 50 series tires.
5. ENGINES: 2300 cc max.
Rods 5.2 or 5.4
Stock Crank
Pistons Cast Hypertectic Coating is allowed
Any hydraulic cam and lifter is okay
No roller cam or lifter of any type
No dual overhead cams Heads: decking of head is okay No porting or polishing of head of intake
Valves must be stock size for head
Heads can be bow cut Ύ from seat of valve (no tolerance on bow cut)
Intake:
Fuel injected intakes allowed
No After Market intakes
1 Adapter No tolerance
Maximum compression 170
6. Electric fuel pumps will be allowed but must have shut off going to oil pressure switch and approved by Tech
Any fuel lines that are routed the interior of vehicle must be in solid conduit.
7. Toyota-Nissan 2000 cc etc.
6. TRANSMISSIONS: Must be stock OEM type with all working gears in standard shift, automatic transmission must have working torque converter.
Clutch: Factory OEM and fly wheel.
Fly wheel must weigh 13 lbs. min.
Scatter-proof bell housing recommended.
7. WEIGHT: weight of cars after race with driver - 2200 lbs.
8. BRAKES: Rear disc ok. Must be OEM rotors & calipers. After market pedals & master cylinders optional.
9. Any header.
10. ANYTHING NOT LISTED WILL BE AT TRACKS DISCRETION BY TECH MAN. IF ITS NOT WRITTEN, YOU CANT RUN IT! PLEASE CALL THE TRACK IF YOU HAVE QUESTIONS 931-796-1890.
11. Track discretion to check any number of cars when track feels it is necessary.
12. PROTEST RULE: $250.00 Bore, stroke, and bottom end checked. $50.00 going to track
*Tech official may penalize any car not conforming to rules with weight*
