NEW UPDATED....Complete Late Model Race Team PART OUT
UPDATED LIST of a COMPLETE part out of a 07 Mastersbilt Smackdown. Car and parts have a total of 38 nights on them unless stated newer. Also selling and parting out ALL extra parts, tools, truck, trailer, 2 engines, anything to do with racing.
Afco reg style shock ends $10 each
Afco alum threaded dummy shock bent shaft $10
Carrera alum threaded 6174 good $50
Carrera alum threaded 6176/2 good $50
Carrera alum threaded 2094 good $50
Weld 15x14 non beadlock wheels. 5 inch offsets $85 each....only 6 left
Weld alum mud plug cover $25
Masters alum midplate & cylinode $40
LF Masters 1 piece lower with QA1 low friction balljoint $75
RF Masters 1 piece lower with QA1 low friction balljoint & adjuster $100
All tie rod tubes, 4 bar tubes, etc with heims $15 each. Tubes only $5 each
Afco brake bias gauge panel $25
New Afco toogle switch $5
MSD 6Al Ignition Box $100
Pack MSD chips around 8000-8500 $20
MSD blaster coil and mount $30
PARTS reverse mt starter $40
SBC block mt starters $60 each
Bert flywheel $40
Bert couplers with HTD drive $40 each
Moroso alum u joint straps $20
PPM alum 5th coil mount 1 ½ round tube $25 (10 races)
All weight clamps $5 each. 1 ½ and 1 inch round tube
All lead .75 lb. around 200 lbs
WMF Alum 19 inch Jbar with adjuster $100
Quick Change Gears $25 per set. LW 648, reg. 648, 686, 697 with cases
PRO LITE Quick Change Gears 6.86 & 6.97 $35 per set with cases
BSB Steel Bearing Birdcages all mounts, clamps $300
PPM travel chain $35
ATL black 26 gallon fuel cell $325
Chrome fuel cell trap door $15
Chrome Dry sump trap door $25
Battery posts & wires $15
Hypercoil springs 425/450 front range, 175-225 range rear (10 races some new) $15 each
All used afco springs $5 each
All air gauges $10 each
New Smack front tee bar $20
Throttle shaft with heims and kit $25
Upper control arms 7 3/4, 8 1/2, 10 1/2, 11 1/4 $10 each
LF 1 piece lower 17 5/8 $50
Masters Smack spindles $50 each
Longacre Cordless impact. 2 batteries and charger and case $175
Fast turn tire tool with 1 inch socket $25
Alum toe plates $40 for set
Buffer/tire grinder with extra grit discs $60
Spring holder rack $35
2 handle fuel jug $15
Funnel $10
Grooving iron heads $5 each #2 #4 left
HOLLEY stock 4412 2bbl 500 CFM carb (5races) $175
STEALTH 4412 2bbl 500 CFM carb $375
(4) steel Jackstands with wide base flat bottoms $15 each
(2) 6 ton jack stands $20 each
Used 5 gallon air compressor (used twice) $50
General roller bearing drawer bottom tool box $275
Helmet bag $15
Simpson suit/helmet bag $30
4 purple foam mudplugs $10 each
Axle strap $10
Dominator hood scoope $15
Plastic interior scoope $15
Bump start with start button and clips (easy valve checking tool) $15
Used 5/8 heims $5 each
Timing lights $20 each
KSE tandum pump bellhousing mount $30
Racers car washing soap ½ to gallon left $10
Plastic trailer jack $25
Heavy duty engine stand $50
Engine lift plate $5
In car fire ext $10
2 alum tran shift arms $5
356 ALL steel Complete engine 450 laps. $4200 OR TRADE TRADE
Most components were bought new 450 laps ago. 010 2 bolt main block 0.35 over. Brezenski Bowtie Vortec large port heads & matching Edelbrock intake, 2.05-1.60 stainless valves, titanium retainers, roller springs. Split 1.5-1.6 Harland sharp/PPM alum roller rockers, stud girdle, alum Jay ****ens alum valve covers, MSD billet dist, Hendricks plug wires, Jones Racing serpitine pulley system, lite weight balancer, alum water pump, New Gm fan, Eagle 45lb lite weight crank, 3.48 stroke 350 mains std/std. Carrillo 6 inch H beam rods 530 grams Honda journal, 300 grams lite weight JE flat top pistons. Tony Barker roller cam, roller lifters, Pro Cam fuel pump, complete running race engine. Ran engine at TNR, Thunderhill, Corinth, Moulton, and Duck River
Best way to get ahold of me is call/text 256-577-3624. I do not get on here much so call/test is best. All parts can be shipped at buyers expense. I am working on pics of these parts as we speak.
PARTS list updated. Trailer is already sold along with rack, hubs, radiator, twm birdcages, gear pan and ohlins shocks
Parts list updated 10-15-13
Parts list updated 10-18-13
Parts listed updated 10-28-13
