Results 1 to 3 of 3
    Apr 2008
    wendel,wv
    277
    Default 2012 rocket chassis blue-grey front wide rf option
    2012 blue front rocket chassis it was max blair's car from last season. selling as roller.
    - Wilwood Reverse Mount Pedals and Master Cylinders
    - Coleman Bearing Gas Pedal
    - MSD 7AL Ignition box and HVC Blaster Coil, and Rocket Wiring Harness
    - QuickCar 4 Gauge Panel and Switch Panel
    - All Brake Lines with Wilwood Electric 3 Wheel Brake Switch
    - Simpson Seat Belts
    - Sweet Collapsible Steering Column Kit w/ 15" Steering Wheel
    - Grey Spindles
    - Wilwood 007 oil filled hubs
    - wilwood Brake Calipers w/ 1.25" Solid Rotors
    - Sweet Rack w/ Dual RF Holes and .235 Servo
    - Complete Lowers (Teflon Heims and Howe Ball Joints)
    - howe blue max Bearing Uppers w/ Howe Ball Joints
    - aluminum radiator
    - All Tie Rods and 4-Link Rods with Teflon Heims
    - Rocket Lift Bar, Upper and Lower Lift Bar Plates
    - 6th Coil Kit w/ 350# Spring and 5th Coil Mount
    - winters crate 8 inch Rear End with Rocket Bearing Birdcages
    - 1 Hole J-Bar Slider and Slotted Pinion Mount w/ seal
    - CV Aluminum J-Bar
    - PRC Rear End Filler Tank w/ Hose
    - ATL Lightweight angled 26 Gallon Fuel Cell (powder Coated blue)
    - Trick fiber glass roof
    -car is in very good shape the powder coat looks new
    has a complete body but it could use new sides. also have a set of genesis d/a shocks for sale. switched jobs and no time to race now.
    rolling car $15,500 304-694-2277
    Apr 2008
    wendel,wv
    277
    still for sale make me a offer
    Jul 2009
    17
    Can u send pics to Wardawgs219@msn.com
