Results 1 to 7 of 7
Thread: 2.3 timing
    Mar 2009
    14
    Default 2.3 timing
    what rpm do you use when setting the timing to 36 to 38 degrees?
    Sep 2007
    208
    I go 7400--7800
    Feb 2010
    233
    Rev it to 2500-3000 to stabilize it while setting.
    Nov 2008
    359
    it all depends where your dizzy stops advancing at. Find that point, usually around 3000 if its set up right, then make your base timing from there.
    118
    You have a locked dist or not?
    Mar 2009
    14
    stock dist, vaccum line disconected,advance not locked, whats a good way to lock it ?
    Jan 2009
    Knoxville, Tn.
    74
    Use the TFI dist and no worry about it moving. It will stay where you set it.
