IMCA Stock Car 360 Motor
What's the Pros and Cons of running a 5.7 versus a 6.0 rod for the 10.5 to 1, 360 IMCA spec motor?
6 inch is said to make more torque on the dyno
racingford
shorter rod is supposed to help torque. longer rod will hold higher rpm hp longer. the longer rod will have a lighter pistons than a comparable 5.7 so that helps with load on the rods and acceleration. i run the longer rods and use a smaller cam to get the torque back.
