Hugh Parts List Late Model/Modified Sell Out
New parts list of my dirt late model part out and parts I have had on shelf from buyouts. Assortment of parts for late models and modifieds. I can ship anywhere at buyer expense. Call or text 256-577-3624 is best way to get ahold of me. Located in North Alabama area
MSD 6AL Ignition boxes (takes rpm chip) $100 each
MSd Blaster 2 coils $25 each
MSD 7AL-2 Ignition box $250
MSD Pro billet distributor # 8360 $165
Seirra mag wide 5 hub..complete with seal, races, bearings, and spindle nut, and rear drive flange $65
Wilwood alum wide 5 hub..complete with seal, races, bearings, and spindle nut, and rear drive flange $65
New standard wide 5 hub bearings…misc inners and outers..around 10 -15 $50 for all
Wilwood front mount clutch pedal ¾ master $85
Wilwood front mount dual master brake pedal with hand adjuster $125
1 used (3 races) PST carbon fiber drive shaft with 8 inch yoke 35 ½ $400
1 used Acpt carbon fiber drive shaft. 39 inch centers with new ujoints $400
1 NEW Wiles carbon fiber driveshaft 35 ¼ new ujoints $550
1 NEW Wiles carbon fiber driveshaft 37 ¼ new ujoints $550
Fast Shafts steel small diameter 35 inch driveshaft with 6 inch yoke $75
Frankland quick Change. 34/35 gundrilled axles, alum tubes, 486 gear with alum spool $600
TWM alum J bar slider mount $65
Afco alum 19 inch J bar with adjuster $75
Round power steering tank & Mount/lines $65
2 GRT 6th coil assemblies $65 each
GRT nylon alum birdcages with brake mounts $150
Pair GRT billet dynalite brake calipers $100
Pair Wilwood dynalite brake calipers $100
Few GRT spindles RF and LFs $50 each
GRT 1 Piece lowers $65
Rayburn LF 1 piece lowers $65
Weld 15x14 HS 10 hole Beadlock 5 inch offset…alittle rough but good usable wheel.. NO RING $75
SEC 15x14 (10) hole NON Bead 5 inch offset…alittle rough but good usable wheel $50
Misc Imca pullpars…Cov spring type and rubber spring types $50-$65 each
Used rayburn pullbar with green spring $50
3 Gauge Panel…Liquid filled…Op, WT, FP $75
Auto Meter shift light tach 5 inch face $65
2 GRT 5th arms…1 complete with heims 1 not $65 and $50
Winters 8 rib alum QC bell with steel tube…21 inch tube, 30 inch total $85
Winters 8 rib alum QC bell with steel tube…25.5 inch tube, 34.5 inch total $85
2 Fuel lines with filters and mounts $50 each
Dynatech MODIFIED headers with Dynatech mufflers $200
Shock pins $1 each
2 sets alum roller rockers SBC…3/8 stud $85 each
New Flo Control Filter assembly $100
Steel swing arm birdcages and swing arm mts $75
Pro Shock kits for alum threaded shock $10 each
Used but good valve cover breathers, $ shielded $3 no shields
3 steel late model/modified steering shafts complete with all ujoints and heims $75 each
Shock ride height tool (chang springs without messing up ur ride height) $15
Afco reg style shock ends $10 each
Afco alum threaded dummy shock bent shaft $10
Carrera alum threaded 6174 good $50
Carrera alum threaded 6176/2 good $50
Carrera alum threaded 2094 good $50
Weld alum mud plug cover $25
Masters alum midplate & cylinode $40
GRT alum midplate $30
Rayburm midplate $30
RF Masters 1 piece lower with QA1 low friction balljoint & adjuster $100
All tie rod tubes, 4 bar tubes, etc with heims $15 each. Tubes only $5 each
New Afco toogle switch $5
PARTS reverse mt starter $40
SBC block mt starter $60
Moroso alum u joint straps $20
PPM alum 5th coil mount 1 ½ round tube $25 (10 races)
All weight clamps $5 each. 1 ½ and 1 inch round tube
All lead .75 lb. around 200 lbs
Quick Change Gears $25 per set. LW 648, reg. 648, 697 with cases
PRO LITE Quick Change Gears 6.97 $25
BSB Steel SWING ARM Bearing Birdcages plus some 4 bar shock mts $300
PPM travel chain $35
ATL black 26 gallon fuel cell $325
Chrome fuel cell trap door $15
Chrome Dry sump trap door $25
Hypercoil springs 14 inch, 12 inch 225, 10 inch 325, 425, 500 (10 races some new) $15 each
All used afco springs $5 each
Used rayburn front/Rear tee bars $10 each
Upper control arms 7 3/4, 8 1/2, 10 1/2, 11 1/4 $10 each
LF 1 piece lower 17 5/8 $50
Masters Smack spindles $50 each 1 set left
Alum toe plates $35 for set
Buffer/tire grinder with extra grit discs $60
Spring holder rack $35
Fuel Funnel $10
Grooving iron heads $5 each #2 #4 left
HOLLEY stock 4412 2bbl 500 CFM carb (5races) $175
STEALTH 4412 2bbl 500 CFM carb $375
Used 5 gallon air compressor (used twice) $50
Plastic interior scoope $15
Used 5/8 heims $5 each
Timing lights $20 each
KSE tandum pump bellhousing mount $30
Engine lift plate $5
In car fire ext $10
2 alum tran shift arms $5
SBC Alum roller rockers. Split 1.5 (Harland Sharps)-1.6 (PBMs). 7/16 stud $125
Eagle 40lb 350 crank. 350 mains, 3.48 stroke, Honda Journal, 10/std $500
Cola 350 Crank. 350 mains, 3.48 stroke, large journal, 53lbs, 20/20. Bought used but never got to use it. Needs polished $125
Carrillo 6 inch rods. 580 grams, .940 wide, .927 pin, Honda journal CARR ROD BOLTS ($300-$400 rod bolts). Need 2 rods to complete ($2600 set of rods) $150
Carrillo 6.200 inch rods. 600 grams, .940 wide, .927 pin, Small journal CARR ROD BOLTS. (2600 set of rods) $350
BBC Child & Albert 5.7 inch Alum rods. .Small jornal,1.45 wide, .927 pin size. $250
Slightly used ISKY Tool Room Roller Valve Springs. All around 250 seat pressure $75 per set..3 left
Misc Edelbrock & Holley & Barry Grant fuel pumps $40 each
Dry Sump System. Weaver Bros. 4 stage pump, Butler tank with Oberg and all lines $550
ALLSTAR alum water pump $40
Misc alum fan spacers 2 inch, 2.5 inch $10 each
New alum timing degree pointer $20
New Meling HV 55 oil pump $40
383 rotating assembly. Scat 48lb 3.75 stroke crank with 350 mains, large journal, polished (used VERY little less 200 laps) and ready to go. NEW Scat 580 grams connecting rods, large journal, .940 wide, .927 pin size. SRP .040 over flattop pistons, fresh flycut (look like new) 400 grams. ALL BALANCED ready for assembly. Nicesetup…Over $2000 invested $1500 OBO
350 4 bolt main block. Nodular main caps, Fresh .040 bore, line honed, decked, New cam bearings and freeze plugs. Fresh ready for assembly. Over $600 invested…. $550 OBO
NEW Dart 50cc 215 Runner steel heads. Fresh 3 angle valve job, New stainless 2.02-1.60 valves, New titanium retainers and 10 degree locks, New Isky Tool Room roller springs set @ 2.000 installed height with 250lbs seat pressure, FRESH ready for assembly…Over $1500 invested … $1000 FIRM
355 ALL steel Complete engine 450 laps. $4200 OR TRADE TRADE
Most components were bought new 450 laps ago. Way over 10K invested…. 010 4 bolt main block 0.35 over. Brezenski Bowtie Vortec large port heads & matching Edelbrock intake, 2.05-1.60 stainless valves, titanium retainers, roller springs. Split 1.5-1.6 Harland sharp/PPM alum roller rockers, stud girdle, alum Jay ****ens alum valve covers, MSD billet dist, Hendricks plug wires, Jones Racing serpitine pulley system, lite weight balancer, alum water pump, New Gm fan, Eagle 45lb lite weight crank, 3.48 stroke 350 mains std/std. Carrillo 6 inch H beam rods 530 grams Honda journal, 300 grams lite weight JE flat top pistons. Tony Barker roller cam, roller lifters, Pro Cam fuel pump, complete running race engine. Ran engine at TNR, Thunderhill, Corinth, Moulton, and Duck River. Garuntee motor is everything I sat it is. Will trade on late model rollers only, vechiles, trailers, what you got.
1 msd dist, Appleton rack, and afco bias gauge sold
Parts list updated 11-11-13
