Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    May 2010
    128
    Default Massive sparks and fire from rear brakes
    The guy help runs Hawk pads I think... We never see rear sparks coming out of the rear calipers. One of the faster guys throws massive amounts of sparks for a few laps. What's the deal here? Is he just running a super soft metallic compound? It's unreal how much some of these other guys throw fire from the rear pads.... What's up with that?
    Feb 2012
    Charlottesville, Va.
    174
    Default Brakes
    Is this happening just under braking or as he exits the corner as well??
    I wanna go Fast!!!
    Sep 2011
    Central IL
    504
    I know this may not be the answer, but how each driver brakes can be different. If your driver brakes more conservatively, then there won't be many, if any, sparks from the brakes. You usually see massive amounts of sparks coming from guys who stomp the brake on entry like they have a stone foot. I have seen guys in stock cars who brake hard enough to get stock ceramic brakes to spark like a 4th of July fireworks show. Also the amount of rear bias that is ran can make sparks. A lot of rear brake means more aggressive clamping, which will give you sparks. Maybe your driver doesn't run as much rear brake as those other guys as well.
    #72W U.M.P Stock Car
    Jun 2007
    3,123
    We run Hawk black pads and I've not had anybody that watches us closely report sparks but I am not an aggressive braker unless the track is stupid fast and that would normally be early in the day when you likely wouldn't see the sparks anyway.
    That being said, I've never felt the need to make my car throw sparks just because the fast guy's car throws sparks. Just food for thought.
    Sparks mean heat, heat means friction, friction means wear. Something else to consider. The really aggressive pads are rough on rotors.
    Not all drivers/driving styles are conducive to aggressive brake packages. Some would call it a crutch to run a less aggressive pad but not all of us are professional drivers :-)
    2,319
    Read Donnie Moran's driving book. That would be my suggestion to the OP.
    BUCKLE UP NOW, YA HEAR?
    Sep 2010
    140
    what is the name of donnies book?
    Huntersville,NC
    927
    mopar92
    Some of the brake testing I have seen here at some brake testing facilities they could be using some aggressive siping on the rotor face as well as a brake pad material to match with the siping. Its amazing you can turn a brake rotor into a lathe........ !!!!!! As the shower of sparks is impressive.
    Pat Collins
    TechWest Racing Services
    MSDŽIgnition Upgrade / Repair/ Technical Support
    8904 Sutherland Dr
    Huntersville,NC. 28078
    704-995-4286
    techwest@techwestracing.com
    www.techwestracing.com
    May 2009
    1,336
    Its all a distraction lol If you watching his sparks you might miss your line
    Sep 2007
    164
    No answer was posted if this was entering or exiting the corner. In dry slick, dragging the brake helps in getting off a corner. Seen a lot of big name drivers doing this over the years.
  10. #10
    tulsa america
    2,686
    Quote Originally Posted by ALF401 View Post
    And if they are wide open in the slick and all of a sudden you see the rotors light up and start sparking its likely they have the brake grabbing traction control.
  11. #11
    773
    Quote Originally Posted by powerslide View Post
    or the driver just applied the brakes himself.....some of us do that sort of thing.
  12. #12
    tulsa america
    2,686
    Quote Originally Posted by sobe92 View Post
    I can see if it started gradually, but when you are on their butt and again we just came off the corner and are to the point where you are usually getting close to wide open and all of a sudden the brakes start glowing and sparking i feel its highly unlikely. Also the car i'm talking about wasnt sparking and glowing on entrance. I understand some of us drag the brake on exit but i wouldn't expect it to happen so abrubtly and go away so quick. Its sad our tech guys can't find these types of units, they dont even try around here anymore.
  13. #13
    I first saw Bloomer doing this in East Bay 3 years ago. even in hot laps and warm up. Most all Bloomer cars do it now and I think Capital . mostly on heavy tracks , heat races , To me it looks like hammerdown on the fuel and braking thru turn even on exit. Obviously the pads have something to do with it !
  14. #14
    Jun 2007
    3,123
    If Bloomquist mounted a j-bar bracket to the rear bumper with nothing even attached to it, half the cars at the track would have one the following weekend and there would be at least two theories explaining why it makes you faster. Some guys WOULD be faster and conclude that this is what made the difference.
  15. #15
    Jun 2010
    Talking Rock, Ga.
    199
    Madden was heavy on them every lap at East Alabama. I never noticed Davenport, Clanton, Weaver or Cook hard on the brakes. Madden was flying! Just an observation and not sure why. Maybe just driving style.
    When it's time to go, I'll go! Until then I got nothing to lose! -Roy Hall
  16. #16
    Ok . More rear brake loosens car , but slows it down , right! Then add power at the same time , car still loose , actually looser , and doesn't slow down. Result is hot brakes requiring high temp metallic pads ! Sparks are the result ! Also would require warming of the rear pads during pace laps which I have noted. Hmmm. Maybe ?
  17. #17
    773
  18. #18
    Jul 2007
    3,224
    Ive ran those, great stopping power but had rotors glowing solid after 2 minutes in tech and cracked to pieces..
    They don't throw too many sparks. dtc 30 are the flame throwers.
  19. #19
    1,903
    Unless they drastically changed the DTC 30 compound it's not those . I ran DTC 30's before and they were useless . I now have wilwood A compound and they have twice the braking power of those DTC 30 pads. The pads making the sparks are supposed to be some
    Old PFC compound that they don't make anymore and Bloomquist bought the last 500 sets or something ridiculous ...
  20. #20
    Dec 2010
    23
    DTC-30 for sure. I've tried Hawk Black, Blue, Wilwood E-pad, Performance Friction 97, and DTC-30. DTC-30 throws the sparks. I have not had an issue with the DTC-30 wearing too fast, or wearing the rotors too fast. I put about 25 shows on a set of pads before replacing them. Very minimal rotor wear. Best pad I've used so far.
