Results 1 to 6 of 6
Thread: Auto Meter Tach
    Default Auto Meter Tach
    Just went to hook up an AUTOMETER MEMORY PRO COMP TACHOMETER 6821 0-10000 RPM. Usually there are 4 wires Green (MSD), Black (GRD), White (LIGHT) and Red (POWER). This tach has a Red, White, Black and then a 2wire wire looks light a lamp cord. 1 wire is black the other is black with white stripe. Any ideas?
    Oct 2010
    422
    Oct 2010
    422
    Quote Originally Posted by MM90 View Post
    So the double black can be used as a green wire? Going to an inductive pick up, this would be the msd correct? Or am i reading wrong?
    Muscatine, IA
    189
    Quote Originally Posted by bigk44 View Post
    I don't think so. It sounds to me like you have the wrong tach for your application. It sounds like you have a tach for a magneto not a distributor.
    Crewchief #21 Modified Hansen Motorsports 2014 GRT by Phillips IMCA Modified
    Quote Originally Posted by BigBlueFord View Post
    Looks like you correct BigBlueFord.
    Anyone need a tach for a Magneto. $125.00 shipped to your door
