Results 1 to 4 of 4
Thread: 14* Steel Heads
    273
    Default 14* Steel Heads
    Anybody out there know what they weigh?
    3,436
    Brand new,unported,not surfaced they weigh 66 pounds each.
    273
    Here is why I asked.New Carolina Clash rules......
    UPDATE:
    The Carolina Clash is nearing completion of the 2014 rules and can announce the tire rule for the 2014 season:
    Open engines: minimum 2300 lbs.
    Hoosier 1300, 1350, 1600 ONLY
    American Racer 44, 48, 56 ONLY
    Steel-block/steel-heads: minimum 2250 lbs AND GM CT 525:
    in addition to tire rules mentioned above, steel-head and CT525 teams CAN RUN American Racer 12 (all four wheels)
    - may run up to 12-inch spoiler
    3,436
    I would look at the RHS raised runner steel heads before I considered the 14* steel heads.If there is no ci limit then the 14* might be worth looking at.
