Helmet Blower
Anyone have any recommendations for a good fresh air blower, or suggestions of which ones to avoid?
Helmet Blower
I run the "Buggy Blower" from FAST, it has a K&N filter on it so it's easy to maintain, I built a quick release bracket for it and installed a weatherpack connector so it could be removed weekly for washing. It works great, going on season 3! I believe it was around $130, wouldn't run without one now that I'm used to it, eliminates fogging!
helmet blower
I don't seem to see it for $145.
QuesinberryRacing
stock car driver
I run a all star blower sytem, it blows a ton of air, I don't ever take it out cant see a need to.
This the Allstar unit you are running?
http://www.amazon.com/Allstar-ALL130.../dp/B006K8GSVQ
Check out the max air blower from Troyer. I think it's the same as the Allstar unit, but should be cheaper than the $180 listed there.
If you run one of the bigger pump styles mount it upside down or it will collect water
if you go on themodified board there plenty of hot air JUST KIDDING
The high price on FAST website is list, hit add to cart and the total on it is cheaper.
