Results 1 to 9 of 9
Thread: Gearing help
    Default Gearing help
    Running a 3/8 dirt track for first time I am running a 2.3 mustang with 225/60/14 tires everyone running there is running 215/60/14 tires and tell me I need a 700 gear with the 215 what's everyone's thought on this I know the ones racing there is not going to tell me what gear they are running thanks for any help hyd head 7600 RPMs I know I need need to get the 215 I can see that but I'm lost on gearing
    Jan 2012
    Lakeland, Florida
    26
    I don't race on dirt any more but I think the 214 trans and 327 rear would be a good combination to start off with.
    May 2013
    19
    2.34 and 3.27 yield 7.65 final drive and if u factor in the your 215/60 it gives u 7.03.
    Thanks T9 is there a formula to detrimine the ratio with the tire size
    Thanks
    May 2013
    19
    I use a gear ratio tire size calculator u can Google it there are a couple good ones
    May 2013
    19
    The best thing is to go to a test session and see what yourmax rpms are and where on the track and go from there
    Illinois
    1,690
    I run a 3.27 rear & T5 in 2nd (2.34) for the 7.65 final. On a 3/8 track with 60 series tires you will be around 8K at corner entry. I run 70 series tires with this same gearing on a 1/3 mile track & hit 76-7800 at the corners. Too many RPMs for a hyd head. IMO you will need taller tires or a 2.73 or 3.08 rear gear.
    2,319
    The 2.14 transmission will likely need a 3.45 rear with 14" tires.
    BUCKLE UP NOW, YA HEAR?
    I run a 3.80 with the 2.14 with 15's and a rollout of 88 on the RR. Not great for restarts, but once you get moving you fly by on the top.Thats an 8.13 uncorrected. 7300...Thats a high bank!
