2010 Diamond Roller, 18* Cornett, Parts, All must go
PLEASE SEE UPDATED LIST
2010 Diamond Clamped Modified, I bought this in 2012 as a chassis, body and front upper and lowers. Everything on the rear was brand new not including the rear end. The rear end was set up by Ryan at Diamond with all new Keyser birdcages and spring mounts, New Diamond pull bar. For 2013 I replaced all the front end including uppers and lowers and spindles. All the shocks are Integras including the left rear Gas pop up shock. All new Hyperco springs in 2013. Winters 4.86 quick change in excellent shape. Aero wheels. Kirkey 15" intermediate seat with containment add ons from Kirkey. Fuel cell was new in 2010. All plumbing is there for fuel and power steering. Set up to run kse tandem pump. All battery cables are there. MSD 6 al with coil on the car. digital telltale tach. Fuel pressure, oil pressure, brake bias gauges. Shifter and linkage there. Aluminum Radiator with screen in front. 12 to 1 box(off impala police car) with 2 to 1 quickner. Very easy to drive and set up. Body is raceable or for patterns. Swivel spring cups. All spares including slick set up shock go with it. Set up manual too. $4700.00 or $4500.00 without the seat
here is a link to video from Eldora. This was a night we qualified and got our time back. We had the quickest time in the heat race. http://youtu.be/piRlHesqaLY
For sale separate:
416 cid 18* Engine, Engine has 7 nights since 100% freshened, 18* Brodix/Cornett top end all cnc heads, Jessel Shaft Rockers, LA Billet Crank and Rods, J&E Pistons and rings, Dan Olson Pan with Wulf remote oil pump. Comp cams special grind(with cam card). Crower hipo roller lifters. Dart Iron Eagle block .010 over part #31122222. MSD distributor. CV serpentine belt drive, Adams aluminum water pump. Fan included. Cam, pistons, rings, bearings, lifters were all replaced when rebuilt. Heads redone by Mike Duke Racing. Very strong reliable engine that can run short tracks all the way up to the miles. $7500.00 obo
KSE new style power steering pump with mounting bracket
part #P16500D $250
MSD 6al spare $80
MSD 6T with soft touch rev control $60
Pro/Cam Baker Alcohol pump $50 pending payment
Chevy oil pump primer $10
HTD belt 600 $5
MSD rev chips 8000,8200,8400,8600,8800 new in msd wrapping $20
Aero white front wheel plug kit complete. part #54500034 $52 new, $25 pending payment
Demon alcohol Carburetor and BG regulator, Came with the engine when I bought it. 1.750 base plate. $250 pending payment
C&S belt drive fuel pressure regulator $35
Bead breaker $20
Allstar starter solenoid new in wrapping $10
Allstar reverse mount starter $80
Schoenfeld Tri Y's for 18* built for a Diamond. Will work on Pierce and others. With bolted on mufflers. $300
Allstar quick change gear pan $30
quick change gears in Allstar cases 5.22 winters, 5.35 cheetah, 5.42, 5.10 winters, 5.86 gem, 5.74 winters, all assuming a 4.86 r&p $25 each
KRC power steering pump and pulley with allstar bracket #48502 block mount, $125
15" fan with 2" spacer with bolts $25
David Daughtery 3175089454 rdracer00@gmail.com I have pictures of most everything and can send them by text or email. It all has to go, Reasonable offers. Paypal or ? Can ship at buyers expense!
