Updated Race Car Parts List
I have a variety of parts for late models, modifieds and street stock parts or just any type racing appliations. I buy, sale, and swap all the time and my inventory changes week to week. I have completely sold out of racing 2 months ago and I always bought and sold parts to keep my racing budget up and keep newer parts on my cars! Now I am just selling! I will try to update list every week. I do accept CREDIT CARDS, DEBIT CARDS, PAYPAL, or US POSTAL MONEY ORDERS. I am working on pics as we speak. BEST WAY TO GET AHOLD OF ME IS TO Call or text for info or pics 256-577-3624. I do not look on here much to check PMs or private messages!!
Misc box of Dzeus springs, buttons, etc new and used $50
Misc box stainless, standard 90 degree Header elbows extentions etc.. $100
Polished alum vortec valve covers needs 1 bolt $50
Joes Racing Stagger Gauge $35
White MD3 Nose New with MD3 sides no floppers $125
MD3 GTO headlite kit $25
88 Monte Carlo tail lites and misc Chevy, bowtie stickers $25
Stealth 2bbl 4412 500CFM carb new billet metering block $400 FRESH
Stealth 650 cfm Gas CRATE carb $600
Barry Brant Phenolic 2bbl carb spacers $25 each
Belt Drive pulley kit with Mandrel..water pump pulley, misc pulleys $85
Saftey Solutions neck restraint $125
CRATE 350 flywheel flexplate & bert coupler $65
Barry Wright Liftbar $100
PIT BOX White Alum pull around pitbox with storage compartments and tool box $750
CSI billet alum swivel water neck $25
Moroso 2 inch Water neck ext cooling unit with braided line $50
NEW Bob Pierce modified 9 inch Fordrear end complete with no gear. Has GN hubs, 810 rotors, spring holders, shock mounts, all bearings, brake clamps, measures 62 inches hub to hub ALL BRAND NEW $700
Shaw modified GN rear 9 inch ford housing $350
New Shaw weld on rear end brackets $25
9 inch Ford 3rd member 5.83 gear NICE $350
New 9 inch Ford Axles 26.5 and 34.5 $50 each
Lakewood steel blowproof bellhousing $125
Longacre Computer Race car scales with 4 inch pads $750
Intercomp Computer Scales with pads. Works but few read out lights out but can still make out numbers $500
All wheels 5 inch offsets except if stated
Weld 15x14 XL 15 Hole Beadlocks $135 each (3)
Weld 15x14 XL 15 Hole beadlock 1 dent in wheel $125
Weld 15x14 XL 15 hole beadlock wheel…needs new ring $100
Weld 15x14 HS 10 Hole beadlock $125
Weld 15x14 5 hole beadlock $100
Weld 15x14 Non Bead XL 15 hole $90 each (4)
Duralite 15x14 15 Hole $85
Weld 15x14 10 hole only 5 usable 4 inch offset $40
Weld 15x12 beadlock needs ring $85
Weld 15x12 nonbeadlock wheel $60
MRT Carbon Fiber Beadlock 15x14 wheels $85 each (6)
American Racer and Hoosier Tires
New American Racer Tire 86 MD56 $60
Used American Racer tires all $20 each GOOD Tread
29.0 SD48
29.0 LSW MD56
29.0 SPEC 56 (4)
88 MD 56
29.0 SES SD48
Hoosier 29.0 1450
Hoosier 29.0 1350
Hoosier 28.5 1350
Steel Wheels
Broad 15x10 Steel Wide 5 wheel Black 2 inch offset $25 each (4)
Broad 15x10 Steel Wide 5 wheel Black 4 inch offset $25
Broad 15x10 Steel Wide 5 wheel Chrome 5 inch offset $35
Older Broad 15x12 Steel Wide 5 wheels Chrome 6.5 inch offset $25 each (2)
Older Broad 15x14 Steel Wide 5 wheel Chrome 6.5 inch offset $25
Broad 5x5 15x10 Wheels 5 inch offset $25 each (2)
Broad 5x5 15x12 Wheel 5 inch offset $25
Broad 5x4.5 15x12 Wheel 5 inch offset $25
Older Broad 5x5 Wheel 15x14 four inch offset $25
Bassett IMCA sticker 15x8 wheel 5x4.75 three inch offset $25
Aero IMCA sticker Beadlock wheel 5x4 ¾l…4.5 offset $65
Mastersbilt PPM alum bearing birdcages. One has been cut& welded on. Nothing major $300 for set
GRT nylon alum birdcages and brake clamps $100
Steel swing arm birdcages and swing arm mts $75
BSB Steel SWING ARM Bearing Birdcages $200
Modified 4 Bar Steel Bearing Birdcages $200
New Landrum Leaf Springs 20-242ML (4) and (1) 42-454 SP $50 each
Assortment of New & used springs:
Blue Coil Conventoinal Coil springs ALL NEW $10 each
5.5-12-900 (2) 5-13-175
5.5-12-800 (2) 5-13-300
5-12-800 5.5-9-1500
Pigtail springs all new
5.5-11-325 (2), 5.5-11-300, 5.5-11-300, 5.5-11-275
AFCO Conventional Coil Springs $10 New $ 5 used
New Afco 5.5-9.5-800
Rest are all used
5.5-9.5-800 (3) 5-13-175
5.5-9.5-900 5-13-275
5.5-11-1000 5-13-250
5-9-600 5-13-300
5-11-650 5-13-500
AFCO Coilover Springs all used $5 each
14 Inch: 225 (2), 250 (4), 275, 300, 325, 350
12 inch: 150, 250, 275, 300, 475, 500, 600
10 inch: 325 (2), 400 (2), 425, 450 (4), 500 (4). 525
Hypercoil spring all have 10 races $15 each: 14 inch 375, 12 inch 225, new 12 inch 125, 10 inch 325, 375
Shocks
1 Set C2P Alum Threaded Gas Canister Shocks with kits!! Having them freshened now and will have dyno sheets…valved for mastersbilt
$1400
Used Alum Afco Threaded Body Shocks. I have may more and will post more once I go through all of them $45 each….99-3, 93, 94, 95-5 (2), 75, 76, 73
Carrera alum threaded $45 each….76,94, 95, 76-2, 75
Ohlins 8 inch stroke rebound adjustable Shock. We added an 1 inch ext and used as a LR traction shock have total of 2 of these shocks $200 each
2 Qwick 9 inch gas shocks alum threaded $50 each (2)
Afco smooth alum 79-1 shock $10
Afco smooth alum S1171-14 shocks (5) $10 each
Pro alum body shocks $10 each….95-6 needs end, 71-14, 79-1
Pro Steel body shocks $10 each…95, 73, 75 (3), 76
NEW Pro Steel Body Shocks $20 each…93 (2), 94, 95, 95-3, 96, 75, 76-3
Afco steel body shocks $10 each ….79-1 (2), 76 (2), 75 (2), 94
Carrera 71-9 shock $10
QA1 5094 (2) $20 each
SOLD
2 Weld $135 beadlocks
all afco 12 inch springs
Kirkey 17 inch seat
Lakewood bell
1 GRT 6th coil
73/5th coil shock 325 spring
new shaw weld on brackets
All new steel body Pros
QA1 used shocks
1 Bert flywheel
597 QC gear
588 QC gear
17 inch steering wheel
Wilwood reverse mt pedals
Afco 26 in radiator
Fresh air pumper/hose
Complete fuel line/Filter
1 rear end filler
SOLD
C2P gas canister shocks
All 15x14 Beadlocks wheels sold
Rons Fuel Pump
Set of 4 dynalite calipers
Clutch pedal
MSD 7AL-3 box
FSR oil cooler
SOLD
GRT 5th arm
1 wildwood hub/rotor
1 used rotor
2 used superlites
CVI swivel water neck
QA1 shocks
Saftey Soulutions neck restraint
C&S 750 alky carb
400 fluidampr
350 fluidampr
QuickCar Tel Tac
Wilwood hanging pedal and adjuster
Sold 10 sets of Gears
NOW SOLD
Rocket chassis pending
Frankland Quick Change no tubes
rocket winters rear end
3 used Pro 75 shocks
1 MSD 6AL box
1 pro billet distributor
coleman mini clutch
1 round Patterson dry sump tank
2 piece alum timing cover
alum 19 inch j bar
wildwood tru trac rack
Appleton 19 1/4 rack
afco 74 coilover
afco 94-5 coilover
Alum oiler valve covers
Magneto tach drive & tach
Krag magneto
moroso balancer
Now Sold
Rocket chassis
Rocket bearing birdcages
Rocket J bar slider
Rocket liftbar
Rocket midplate
Oval craft red set
Lakewood bellhousing
All 35 inch gundrilled axles
34 inch gundrilled axles
chrome gauge panel
power steering tank
Afco switch panel
afco battery on/off switch
Rocket 6th coil
Rear filler tank
2 Wilwood NDL calipers
1 inline fuel filter & brackets
22 gallon fuel cell
1 Ohlins adj shock
Appleton power rack
Sweet dual #3 rack
Tire buffer
spring rack holder
Do you still have the 14" and 12" coil over springs?
is pulley set for crate motor? still have crate coupler?
I have another crate flywheel. pulley set is gone
I do still have some 14 inch and 12 inch springs. what rate and I will check
