Wanting to build a 2 barrel engine using a stock SBC 400 block. Thinking about a 377 or 400 cubic inch motor. I have done a lot of reading and hardly no one recommends these blocks? Everything says use an aftermarket block. I understand the 509, two bolt main block appears to be the preferred one to use if you use one. If the machine shop says the block checks out ok, at approximately 500 hp and 6500 rpm, will one of stock blocks be ok?Thanks for any info!
