Draime IMCA Spec engine 10 nights since fresh
I have a really nice IMCA Spec engine built by Draime. It has a Chevrolet 3970010 block machined with splayed caps, setup for dry sump. There is a ton of machine work done to the block. It has a Callies crank I think its a magnum crank but cannot remember. LA billet rods JE pistons custom ground camshaft Isky roller lifters. It has a aluminum drysump pan with 2 pickups on the pan and one in the valley, lifter valley has had some polishing on it to help with oil drainback. The heads are IMCA spec with all the imca logos intact. T&D shaft rocker system with isky tool room valve springs and stainless valves. It has 10 Nights on it since it was freshened. It comes with waterpump distributor and carburetor. 7500$ Will include drysump pump, tank, powersteering pump and oil lines for 1000$
Located in Omaha NE 68138
