Huge parts list for sale!!!!!!!!!!!!!!!!!!!
Dry Sump Pumps
Wulff Stage 5 $350
Weaver Brothers Stage 3 Pump, Pulley & Belt $225
518 Gear $25
522 Gear $25
511 Gear $25
5.28 Franklin Gear $25
C&R Gear Set 17 New $75
Bert Bell (Ear has a Chip) $125
Bert Starter New $145
Bert Coupler w/ Flywheel $75
Bert Flywheel $20
Remote Oil Filter $15
Halon Bottle with Cord $65
Halon Bottle $50
Mallory Tach $25
Autometer Tach $25
Autometer Tach (From Nascar Team) $100
Woodward Rack $400
Sweet Rack $225
Appleton Servo $50
Steering Rack $75
Firewall Grommet New $10
Carb Spacers
HVH 1 inch spacer $75
HVH 2 Inch Spacer $100
Base Plate $15
MSD Firewall Through New $10
Water Pump Chevy $30
Waterneck with Spacer (Swivel 16AN) $75
Roller Bearing Gas Pedal New $80
NEW shock Gauge $60
Power Master Alternator (Tested Good) $100
Ring & Pinions From Hendricks & RCR Teams (In Great Shape) $125 Each
3.10 Ring & Pinion
3.50 Ring & Pinion
3.60 Ring & Pinion
5.43 Ring & Pinion
4.71 Ring & Pinion
3.16 Ring & Pinion
3.50 Ring & Pinion
Switches & Hold Downs $30
Tube Grease $5 Each
Fuel Pumps
Ford Fuel Pump $50
Carter Fuel Pump for Parts $15
Carter Fuel Pump $50
2 Fuel pumps $5 Each
Braided Line
Braided Line 60 Inch 16AN 1 90 1Str (2) $35 for Both
#8 & #10 Hoses & Fittings $20
Full Flow Fittings #10-#8, #10-#6 $15
Fittings #3-1/8, 1/2 Pipe, 3/8-1/8 reducer $15
Quick Connect & Assortment of Fittings $20
#8 90-str, #6 90-45 Lines $25
16AN 6ft Braided Line & Fittings $35
Carbon Fiber line 70 1/2 & 75 1/2 16AN 45 & Straight $40 for Both
16AN to 12An Reducer $8
Radiator Hoses
2 1/2 Dayco Gold Stripe 22Inches Radiator $25
Dry Brake Pcs $5 Each
10 Ton Port-a-Power $75
Brake Pads
New Performance Brake Pads 7772.93.30.34 $30
New Performance Brake Pads 7735.80.20.34 $30
New Performance Brake pads 7770.83.28.34 $30
New Performance Brake pads 7735.80.22.34 $30
Wilwood Brake Adjuster New $65
Brake Adjuster (Can’t find name on it) $15
Stewart Brake Development $20
3 Brake Fan Coolers $10 Each
New Performance Friction Brake Rotors $45 Each
323.32.0046.37
313.32.0042.37
Tire Grover $50
MSD Box $75
MSD Hot Box $125
Radio Wiring $30
Seatbelts
Simpson July 2010 $30
New Racequip March 2014 $58
Schroth Seat belt Hardware Huge Stack $150
Spring Rubbers Big Springs $5 Each
Jack Screw Used $2 Each
Jack Screws New Have Different Sizes $4 Each
Adjuster Sleeves Used (6) $4 Each
Slugs $5 Each
Oil Cooler $40
Oberg Filter $30
Rear-end Pump $100
Aluminum Power steering Tank $50
Oil Pump Bracket $10
Sweet Powersteering Bracket $15
Regulator $40
Aluminium Brackets 1 ½ $15
Remote Master Cylinder Parts New $10
Blue Streak Plug Wires $30
Motorola Chargers (3) $20
Motorola Batteries (3) $20
Motorola P110 (7 Radios, 8 extra batteries, 3 individual chargers, 1 6 radio charger, 6 radio clips) $500 OBO
Used Upper Control Arms $5 Each
10 1/2
6 ¾
5 1/2
7 1/2
7 1/2
7 1/4
9
8
10
9 3/4
8
8 3/4 1 1/2 Positive Caster
9 1/4
7 Positive Caster 3/4
7 1/4 Positive Caster 3/4
7 Positive Caster 9/16
7 1/2 0
Window Nets
Window Net 23 x 16 Sept 2010 $10
Window Net 26 1/2 x 16 Dec 2012 $15
Oil Tank Heaters $10
Autometer Shift Light $35
MSD Shift Light 8700 Chip $45
Exedy Racing Clutch Like New $200
Push Rods
Push Rod 8.25 Assortment (22) $10
7742 Comp Cams 8.250 .080 (6) $5
7934 Comp Cams 8.550 .080 (4) $5
7121-8075 7/16 x .120 8.075 (4) $5
Assortment 8.700 $5
1/2 x .188 8.010 single taper (7) $5
8.850 .165 DBL Taper (6) $5
Kriner Race Engines 8.445 (4) $5
8.650 .165 (6) $5
CV 8.650 .080 (3) $5
CV 8.400 .080 (6) $5
CV 8.850 .080 Taper (5) $5
Assortment of Sizes $5
16 New Del West Retainers $30
RODS
6.125 Carillo Rods w/ bolts $150
6.00 Carrillo Rods w/ Bolts $150
6.125 Carrillo Rods w/ Bolts $150
6.200 Carrillo Rods $125
Valves
Del West Valves 2.15 Stem Size 6mm $30
Xceldyne Valves 2.15 Stem Size 6mm $30
Del West Valves 1.62 Stem Size 6mm $30
Wrist Pins
Wrist Pins Capricorn 20mm 7.87 Hardened $25
Roller Rockers $50
3 Trans Line Up Shaft & Pilot Bearings $5
Trans Mount Energy Suspension $10
Pit Gun From Nascar Team Parts Sell $150
Quarter Master Throwout Bearing $75
JJones, Please e-mail, text, or give me a call. I'm interested in a few different parts. Jordan White 9285815570
Interested in some parts shoot me a email or text 6016166507 or mobileoil16@yahoo.com
