Results 1 to 13 of 13
    Default Taking tires off the rim
    Over the last several days, I been trying to take these old tires off of the weld rims. Its highly impossible after I bent 2 handles on 2 tire breakers. I went to two service stations and they told me they do not have the right adapter for the wide 5 rims. Anyone have suggestions?
    Jul 2008
    545
    Leave them out in sun then use a tire hammer to loosen the bead up.
    Spray penetrating lube around the beads let sit then heat the inside of the wheel with a propane torch around the bead area. Then they will pop off easily.
    Jan 2008
    INDIANA
    304
    if all else fails cut the bead with a wiz wheel
    Apr 2008
    155
    Must be Falken non beadlocks
    Jul 2007
    538
    Time for the cut-off wheel or sawzall.
    I agree with wisdirtfan... propane torch, carefully heat the aluminum wheel at the bead area inside the wheel, not on the lip you will soften the lip and bend it too easily. Works every time for me even on the most stubborn ones... even on my modified steel wheels with soft sidewall tires that won't break the bead seat.
    I had this happen on valken and older weld wheels. Heating the bead and penetrating oil worked like a charm. Btw I will never buy valken wheels again we got a deal on them when we started and they are so soft the slightest bump into anything and they are bent. I guess that's what you get for buying Chinese wheels lol.
    Apr 2013
    163
    I've had issues with Valken wheels in the past.. All I did was go around the bead once... Then sprayed wd-40 around the bead.. Let it sit for a few minutes and the tire popped right off...
  10. #10
    Sep 2013
    158
    Put some reqular gasoline around bead let set ten minutes will pop off like butter guaranteed
  11. #11
    Aug 2009
    668
    Quote Originally Posted by bowtech View Post
    x2 with the gas, however, we let it sit in the sun for for a bit before we put the gas on.
  12. #12
    take the air out of the tire!
  13. #13
    Sep 2013
    158
    Dang aint never had one gas wouldnt break lose
