Results 1 to 6 of 6
Thread: Caliper mounts
    Oct 2008
    687
    Default Caliper mounts
    Just mounting up some new birdcages. The last set had the caliper mounted to the cage. This set has separate caliper mounts.
    Should I drill and tap the tube? I would assume the clamping force alone would not be enough? Or just drill the tube? Does it need to be tapped?
    Thanks.
    Batavia, OH
    13,666
    Quote Originally Posted by keeks View Post
    Thanks.
    Drill and tap is the best way. I have gotten away with just dimpling the tube and using a set screw, but that is being awful trusting.
    Atomic - 2
    Oct 2008
    687
    Nice! Thanks!
    Aug 2009
    1,088
    I have always just drilled them and had no problems.
    Mar 2010
    272
    Thanks.
    Drill AND Tap the tube!! tap the bracket and the axle tube as one continuous thread to eleminate any slop. use a minimum of 3/8 bolts, 7/16 is best - 1/2" starts to compromise the tube integrity.
    i have seen 3/8 bolts installed properly and still shear off - heavy track on the brakes hard to avoid a crash. in most cases you'll be fine but if it cuts loose it might end your night.
    Sep 2009
    832
    Quote Originally Posted by JTSjet View Post
    You can always use 3/8 bolts and do both sides of the tube. That would be stronger than one 1/2" bolt.
