Results 1 to 8 of 8
    Dec 2007
    138
    Default Temp sender/guage location?
    I have an IMCA spec engine with cooling lines front to back in intake manifold ports.
    My question is can I use water pump ports for dummy light and guage locations?
    Trying to avoid using the riser under thermostat housing.
    Curt Drake
    IMCA late model #55x
    Nov 2012
    Wisconsin
    3,119
    If you have a spot in the heads I would use that… I don't think the H2O pump is a good place for a temp sender...
    Jun 2007
    LAS VEGAS, NV.
    791
    Don't the heads give a faulse reading?
    »»*†HÀ†§ HÓ††™««
    Are'nt you only getting cooled water from the radiator at the pump
    3,436
    No reason not to use an adapter under the thermostat housing.Everone does.
    Dec 2007
    138
    Only reason I don't want to is it raises water neck above radiator, possibly trapping air, and intake is already plumbed front to back, so I would have to move cooling lines to adapter, and sensors to intake, not really a big deal but if I don't need to do it, I wont.
    Curt Drake
    IMCA Late model #55x
    2,319
    3,436
    You don't need to move the lines to the adapter,just put the sensors in the adapter.
